Old 07-09-2016, 08:44 AM   #29
Agent 86
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The impact is most useful for taking the old bolts out, for putting the new ones in we just tightened them till they felt right and then checked them with a ratchet.
Superat stultitia.
Old 07-09-2016, 08:19 PM   #30
KYAirstream's Avatar
Northeastern , Kentucky
Changing axles next week...
Dropped one axle today. Was pretty easy, with the exception of the bolts that attach behind the axle shock mounts. Not much space to get a socket in there with the water tank in place, so I dropped the tank as well. Was surprised to see there was nothing except the sheet metal wrap holding the tank up. Lots of funk in the metal pan, so it needed a good cleaning anyway. While I've got the pan dropped I'm thinking I'll go ahead a drill a few weep holes.
Also need to enlarge the notch for the axle tube by about 1/4 inch. Should not be too hard with a small cut off wheel.
KYAirstream is offline   Reply With Quote
Old 07-09-2016, 10:20 PM   #31
1979 23' Safari
Wayland , New York
Suzy
Photos of the trailer with both axles swapped with the lift done. Also photos of the lift kit installed would be very helpful if you got any. Thinking of putting on lift when I swap my 23' axles. More room for boondocking.
Thanks, Joe
Old 07-09-2016, 10:41 PM   #32
JJA
Missoula , Montana
This will be completely unhelpful but I pulled the shell, belly pan, rebuilt the frame, flipped the frame over, cut the old axles and springs and hardware off with a torch, welded on new plates, mounted dexter torsion axles and welded them on.
Only time I've replaced axles on anything. Don't recommend it and hope I never have to do it again...
More detail on my project blog: http://67streamline.blogspot.com
JJA is offline   Reply With Quote
Old 07-09-2016, 10:59 PM   #33
JJA
Missoula , Montana
Lifting
Originally Posted by HiJoeSilver View Post
Suzy
Thanks, Joe
I did something like that. Mine was a frame off so I was able to lower the wheel wells a couple inches (new ones were custom made by an HVAC guy), put torsion axle on at a tilt that gave me 2" and then went with larger tires to give me a total of 3". I've only had it out once but here are some pros and cons to consider:
Pros
easier to crawl under
easier for me to get at dump valves
won't drag in street/driveway dips/bumps (although it didn't before either)
3" less bending over for most things on the exterior
Cons?
Like you, I did this for boondocking but now that I've put so much time & $ into it, I'm not sure I want to drag it down gravel roads...especially after seeing a trailer where the tires spun and spitting gravel trashed the front.
Mine has a narrow & welded step into the main door. Now it really needs a second step but there isn't a good way to add one. I'll probably use one of those little steps that looks like a stool.
Would I do it again? Maybe but it's honestly not the slam dunk I thought it'd be.
Old 07-10-2016, 09:08 PM   #34
I meant to ask before if 32 degree axles should be at 32 degrees prior to install? Mine are closer to 28 degrees.
Old 07-11-2016, 05:40 AM   #35
Verified the mounting bracket of one axle is good and level this morning before measuring the angle of the arm. The arm is at 26 degrees, which seems a long way off from 32. This is unweighted.
Old 07-12-2016, 02:24 PM   #36
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
Suzy
Thanks, Joe
Let the people rejoice! Both axles are on, road test went great, life is good! I wound up gaining about 6", including the lift kit and the dud-to-new axles. I shall fear no supermarket driveway again!
A wise person (J.Morgan) cautioned against the hollow plastic ramps. Attached pic shows what can happen to them! Fortunately, the Dept. of Redundancy Dept. had placed extra jack stands all over the place, so no harm was done.
I am in awe of Silver Hawk, who did this job by himself in 4 hrs! It took 1-3 guys the better part of two days, not including beer runs! At two trailers a day, Silver Hawk could set himself up in a fine retirement business!
As to the lift kit, it hides behind the frame, and uses the existing holes for attaching. The axles have holes on top of the mounts (mine were bolted to the pallet with them) that attach to the lift kit. As mentioned above, you might have to adjust the holes in the kit to get them to fit the frame. Mine were 3/8" off.
Thanks again to all that contributed their wisdom!
Name:	2016-07-12 12.52.41.jpg
ID:	266589   Click image for larger version
Name:	2016-07-12 13.56.35.jpg
SuzyHomemakr is offline   Reply With Quote
Old 07-12-2016, 04:04 PM   #37
1979 23' Safari
Wayland , New York
Suzy, Looks good, it's a beautiful trailer. At least in the picture, it doesn't look ridiculously high or anything from all the lift. I think I'll be following suit on my trailer.
KY, what are you measuring the angle with?
Old 07-12-2016, 06:59 PM   #38
HiJoeSilver-- I just started a new thread on this issue called "Are axle down angles correct?"
Old 07-12-2016, 11:22 PM   #39
Agent 86
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Your trailer looks awesome, and I love the way it sits.
Great job! (All around great job, I love it)
Gradiens super tenui glacie.
Old 07-13-2016, 11:12 AM   #40
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Picture looks great. And I would think the lift would be less noticeable on a larger trailer. And smaller trailers would not need the lift because the over hang is less.
Good job no matter how long it took.
>>>>>>>>>Action
Old 07-13-2016, 06:59 PM   #41
1976 25' Tradewind
Sulphur , Louisiana
How did you get ahold of Colin? I emailed him Monday and have not received a response. Should I call or is there a secret knock or password?
Bobkatbry is offline   Reply With Quote
Old 07-13-2016, 09:54 PM   #42
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
Suzy!
Thanks for sharing your experience.
Your trailer looks great and I'd really like to get a lift kit under mine after looking at yours.
Just wondering, how did you make sure your axle alignment was good--or are the holes in the lift blocks precise enough you can't really bolt the axle in crooked?
Thanks!!
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Newbie from UK - heading to the US next week! :) roadtrippers Member Introductions 15 04-15-2011 09:21 AM
TAC : Shenandoah Next Week pmclemore Forum Rallies & Meet Ups 7 04-19-2010 10:50 AM
FL-Smoky Mtns next week, any suggestions? kstampa On The Road... 6 09-14-2008 09:55 AM
airstream rally france coming up next week end Perry Other Rallies & Events 2 07-28-2007 06:32 PM
Focus Group to Meet next week -- are you IN??? Mr Jody Hudson Our Community 8 07-29-2002 07:35 AM
