Don:
What do you use for weights? I have heard of strip weights used to balance mags - is that what you are using?
The Dexter hubs have a large lug (see about 10 o'clock position) http://www.airstreamphotos.com/photo...cat/500/page/2
which was right where most of the weight needed to be removed. I ground off about 1/4 of the lug with a die grinder. The remaining weight was removed from the top of the fins where needed.
