06-22-2004, 02:41 PM
#21
2001 30' Excella
Bedford
, New Hampshire
centramatic update
I needed to replace the outer bearing on one of my wheels. I thought this would be a good opporturnity to test andy's position that the hubs and wheels need to balanced together. I took the hub, the wheel and tire to my mechanic.
The tire was brand new and the wheel and tire was balanced by the people who sold me 4 new goodyear marathons.
My mechanic spun the wheel and tire and was comfortable with the balance done by the tire people. He then spun the hub. The hub was 3 oz out of balance. He said the inside of the hub was perfectly round and should not present any problems with the brakes. But, the outside of the casting was not round.
He then mounted wheel on the hub and spun them again. He weights on the wheel had to be changed substantially. He painted the wheel stud next to the air thingy so that I could re mount the entire assembly correctly.
I mounted the assembly on the AS with the centramatic. I'm confident this procedure should eliminate any and all vibration in the running gear of my AS.
-Life is a journey, not a destination.
Aerosmith
08-06-2004, 05:27 PM
#22
Both???
Has anyone had their entire wheel/hub assembly balanced AND used the Centramatics?
This would start with everything true and the Centramatics would keep it in check...yes?
This is a quote directly from their site, "Brake drums and hubs should also be balanced. Balancing the tires and wheels only corrects half the problem. As drums wear, there is an increase in imbalance."
Any thoughts???
08-06-2004, 09:15 PM
#23
I can understand tires getting worse as they wear. Why drums would get worse with wear is beyond my understanding. Would seem to me there is a 50:50 chance of getting better or getting worse.
08-07-2004, 10:31 AM
#24
Originally Posted by markjoandall
I guess we were lucky to have made it home. I now have four new goodyear marathon's on order. I also have a spare rim on order, for some reason we never got a spare with our trailer. I'm going to use the Cooper for our spare.
Wow, first you're very lucky that the blow-out did as little damage as you described.
Second, I am surprised that you decided to replace with anything other than Cooper.
I have to relate so you will understand my opinion. I have run almost every tire made at one time or the other. Now I know new technology has made things better so some of my tire experiences are really of no weight. However, there is one thing that really stands Cooper far above the rest, Cooper replaces tires that prematurely go bad with no cost to the customer. All of the other companies want to prorate the tire by thread wear and charge you the difference in selling you a replacement tire. Also in my experience I have gotten more wear from Cooper Tires than from any other tire.
On my Cadillac I had a problem with a tire that had an 80,000 mile warranty and Copper had discontinued the tire so they removed all 4 of my tires and replaced them with the 75,000 mile tire for free, and they gave me a new warranty for the new tires. Total cost to me was $Free.
On the other side of the coin, Centramatics are one of the best items that a road vehicle of any kind can have on it. I have used them on very large semi trucks and trailers in the past.
I thought that they were only manufactured for large rigs so I never bothered checking, but since this thread has enlightened me I will be purchasing a setup for my 2 trailers as well as a set for my PU truck and my car.
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
08-07-2004, 10:41 AM
#25
Brake drums are trued when they are re-cut when they do a brake job as I understand it.
I guess the only way they get out of balance again is from the wear from braking. In that case the Centramatics wouldn’t be a cure all, but they will certainly help by reducing the ill-effect of an unbalanced tire.
John G
08-07-2004, 11:04 AM
#26
Contributing Member
Austin (Hays County)
I put on the Centramatics without balancing the wheels/tires. So far, with over 8000 miles of travel, there is absolutely no indication of any vibration in the trailer.
Before the Centramatics, I had things moving around, screws in the lights backing out, and black marks in my plastic silverware tray and in the pantry from vibration. Since the Centramatics, there are no more black marks and things in the trailer stay put so well that it is amazing. Even the towels always stay on the towel bars whereas they would often be on the floor before the balancers.
Best $200 I have spent on the trailer and I would recommend them to everyone who has 15" wheels. Sadly, they would have helped some vibration problems in my 2003 International, but that had 14" wheels.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
08-07-2004, 07:47 PM
#27
2001 30' Excella
Bedford
, New Hampshire
Blrpx
I've had the drums, wheels, and tires all balanced as a single unit. Then when I mounted the wheel assembly on the trailer, I also mounted the centramatics.
I have just completed an 8,000 mile trip with the trailer and like John Irwin, everything now stays in place in the trailer.
I closely watched my mechanic balance the wheel and hub assemply. The wheels that I have on my trailer are from Dexter and the castings are just not round. The inside that is machined for the brakes are perfectly round, the castings are not. I had two drums that were over six ounces out of balance. Add that to wheels and tires, you can get quite a bounce going back there. Over time, with that kind of out of balance, the belts break and then the tires blow.
Curiously, I periodically would check the wheels and tires for heat. After this last trip and the extensive balance job I did, the wheels and hubs ran much cooler. I was surprised.
All in all, I very pleased with the balance job and equipment I have on the trailer. I only wish I'd have done it when the trailer was new.
Mark
Aerosmith
08-09-2004, 09:03 AM
#28
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Blrpx
Mark
Mark, where'd you get the balancing done? around here? seems to be a difficult to find service. Might be worth a trip up your way.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
08-09-2004, 09:45 AM
#29
Mark
Mark,
I'm curious how old the Dexter drums were when you had them balanced. I got Dexter hubs last year and they were pretty good, within 1 1/2 oz. No problem with centricity. I wonder if they are improving their QC, or if I just got lucky.
08-09-2004, 10:47 AM
#30
centrametrics alone...
Seems like a lot of trouble to get the whole assembly balanced...will just the centrametrics do the trick as John Irwin states here? He says WITHOUT balancing the assembly?
08-09-2004, 11:48 AM
#31
Contributing Member
Probably depends on the particular trailer. In my case, the Cenramatics apparently do the whole schmear all by themselves. Probably because my drums were reasonably close initially. It may not work for everyone as well as it did for me, but will surely help a lot in all cases.
John W. Irwin
WBCCI #9632
08-09-2004, 12:01 PM
#32
Contributing Member
What bad balance can do
My old TrailManor had a single Dexter 3500# axle. I had the wheels/tires balanced, but not the hubs. I knew that I still had a lot of vibration because there were a lot of black marks from things moving around and a lot of screws backing out.
I had just replaced the awful original blue carpet with a nice Berber carpet before a trip to Florida. When I started back, I noticed that I had left a plastic bottle of charcoal starter on the picnic table, so I put it into one of the bottom cabinets.
When I reached home, I opened the trailer to an awful smell of charcoal lighter fluid and the Berber carpet was a total mess. A hole had worn in the bottom of the lighter fluid bottle from vibrating against a screw head and the leaking fluid had dissolved the rubber backing on the Berber carpet in the whiole center part of the trailer. Fortunately, I had a large piece of the carpet left over to fix the mess, but I had seams where I didn't want seams after that.
My Airstream showed some indications of vibration before the Centramatics, but none after I installed them.
John W. Irwin
WBCCI #9632
08-09-2004, 12:10 PM
#33
Wow
Crazy what vibration can do...thanks for the illustration.
08-09-2004, 05:01 PM
#34
2001 30' Excella
Bedford
, New Hampshire
Chuck,
I just went to my local mechanic in Merrimack, NH. His name is Paul at Auto Workshop on Daniel Webster Highway. If you want to call him, PM me and I'll give you his number.
I pulled the hub and wheels off the trailer, took them to Paul and he balanced the entire assembly. He had to remove the bearings from the hubs. He pained the wheel stud white closest to the air valve. That way, when I remounted the assembly on the trailer I was sure it was the same as when they did the balance job. He also repacked the bearings in the process.
I'm very pleased with the results.
Mark
Aerosmith
08-09-2004, 05:08 PM
#35
2001 30' Excella
Bedford
, New Hampshire
Don,
The drums I have are original with the trailer. We own a 2001 classic 30. When I had the assemblies balanced, the drum castings were perfectly round inside where they are machined. However the raw castings on the outside are not machined and were visibly out of round. Two of the drums, when spun on the balance machine without the wheels, were over 6 oz's out of balance. I agree that the quality control is very suspect.
Aerosmith
08-09-2004, 05:50 PM
#36
Mark,
I balanced the drums in my shop using a semi-dynamic method. It was a labor of love, can't recommend it to anybody.
I had a brand new set of drums and new bearings. I set it up on my new axle, used light machine oil on the bearings, marked around the diameter with indexing marks, and spun the hubs by hand. I recorded the stopping points after spinning 10 times in opposing directions. I added weights until the drum stopped at apparently random locations.
When I repeated the experiment, I discovered a second order imbalance. This showed up as a slight tendency for the drum to stop at marks that were 180° opposite. After i corrected this "dog-bone" effect, the drums would stop at statistically random marks.
I didn't see any run-out on the outside circumference. I think I was lucky to get a good set of drums right out of the box. One drum took about 40 grams (1.4oz) of weight correction, the other less than 20g. (0.7oz)
08-09-2004, 07:40 PM
#37
1962 19' Globetrotter
2001 31' Excella
Sounds like it's worth the $200. Can anyone who has ordered them let me know the part #?? I was just on the Centramatic website and the only system for 15" wheels is listed under "300 Series, For Jeeps, Pick-up's, SUVs".
08-10-2004, 07:47 AM
#38
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Chuck,
Mark
good to know that the service is available. I'm wondering, though...since you had the entire assembly balanced, why do you need the centramatics? to compensate for future wear?
wondering also if my brother-in-law could balance a brake drum. he's got a driveshaft balancing lathe....
Air:291
Wbcci: 3752
'73 Safari 23'
08-10-2004, 10:16 AM
#39
Craig,
The Centramatic Balancers for my dual axle 1995 Excella Classic 1000 with 15 inch wheels and six lugs with 5.5 inch spacing are Part # 300-556. If your wheels and hub match these specifications, they will fit.
The Centramatics don't know what kind of rig they are on. If they fit the wheel and hub, they will do their job.
et
08-10-2004, 10:49 AM
#40
Creampuff
2022 27' Flying Cloud
2016 25' International
Airstream - Other
Malibu
One drum took about 40 grams (1.4oz) of weight correction, the other less than 20g. (0.7oz)[/QUOTE]
Don:
What do you use for weights? I have heard of strip weights used to balance mags - is that what you are using?
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
