Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 10-28-2009, 02:51 PM   #1
sumsmug's Avatar
Profile:  1985 25' Sovereign
1966 17' Caravel
Philly , Pennsylvania
caravel axle sizes
Hi all
I have to move our 1966 caravel to get it registered this weekend. In the medium term I will be replacing the axles, however to just get the paper work done I'm going to repack the bearings and maybe replace the brakes. Can someone please tell me what seals I need and what size of brakes etc..?
I wont be able to get to the airstream until the weekend, so I can't go investigate on the actual trailer.
Thanks everyone,
Caius
sumsmug is offline   Reply With Quote
Old 10-29-2009, 03:15 PM   #2
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
You might get the answer you seek. However travel trailers are not like cars and trucks. Many times the year make and model mean nothing when buying parts. It is the old part that determines what is needed. In my case I took the old seal to NAPA and they matched it up and got me 4 new seals.
Hope you find what you are seeking.
>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 10-29-2009, 03:36 PM   #3
Profile:  Corona , California
Originally Posted by sumsmug View Post
Hi all
Thanks everyone,
Caius
There are 2 differnt sizes of grease seals that was used on that model.
Best way is to determine the inner and outer bearing numbers.
With that info, we can help you.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 10-29-2009, 04:24 PM   #4
sumsmug's Avatar
1966 17' Caravel
thanks guys...I guess I'll go pull them out this weekend and check it out.
Caius
Looking for 67 Caravel axle choices Barkingdogg Axles 8 04-01-2008 05:30 PM
Caravel Axle Replacement Melody Ranch Axles 19 02-14-2007 10:08 AM
What should a 65 Caravel with a new axle go for? fun2bethad Trailer Values 9 10-11-2005 03:57 PM
caravel fuse sizes? Longhorn Electrical - Systems, Generators, Batteries & Solar 3 08-07-2005 02:10 PM
New axle for a 1965 Caravel C Johnson Axles 1 02-23-2005 03:10 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
