Old 01-11-2008, 10:15 PM   #1
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
I received an email today from a friend who was offered a '67 Caravel for what appeared to be a very reasonable price. The initial pictures he sent showed a nicely polished, clean interior, unit. Based on those pictures the trailer was probably worth 5 to 6 times what he was asked to pay.
Then he sent the "rest of the pictures" and it turns out its a major project and not worth a 1/3 of what is now being asked. At 60 mph the right side (curb) spindle broke when it probably hit a pothole along the shoulder of the road and the trailer went down into the gravel on the shoulder. It turned sideways a bit, and the spindle on the other side snapped off in the exact same spot. It skidded along on it's belly pan until it stopped. It did not roll nor get hit by the traffic - so no one was injured.
Basically from (and including) the door back the bottom third of the trailer is destroyed. The water heater is mangled, the door frame is broken, bottom cupboards are ripped away from the wall and two snapped spindles are clear in the pictures. The frame is bent, the belly pan is torn off, the floor is also broken.
In hindsight replacing the axle would have been relatively inexpensive but the owners did not realize that this type of thing could happen to an axle. I also understand that these people were not knowingly negligent, the bearings had been properly greased, it had good tires on it, but the axle gave out.
We often have folks on the forum telling folks looking at buying an old trailer that the axle looks like it needs to be replaced and to many that is a scary thought. They have visions of the costs being exorbitant and decide to just "run with it" and see what happens. The price one pays for not doing it may be far dearer than anyone would wish.
Sadly, the Caravel was not insured. A sad ending to a beautiful little trailer.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 01-11-2008, 10:33 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Sadly this has been a common issue for these trailers. Take a look at this one:
'65 Caravel - Axle Damage
Richard
Old 01-11-2008, 10:43 PM   #3
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I can guarentee you, changing the axle was worth every penny, and I paid professionals to do it! Since your trailer only has one piece of 'running gear', I figured if you can keep it rolling, everything else can be fixed when you roll back home. Too bad those folks didn't know that could be a problem before it was too late!
Stephanie
Old 01-11-2008, 10:50 PM   #4
Miss Rivette
airedale's Avatar
1965 17' Caravel
Hell , Michigan
Send a message via AIM to airedale Send a message via MSN to airedale Send a message via Yahoo to airedale
yea, we replaced mine this past spring, its a nice peice of mind!
Laura Miss Rivette 2008
W8JUZ --......--
"Support Search and Rescue, GET LOST!!!!"
Operation "SAVE RUDY" Strike Team (Charter Member)
Check Out My New Airstream Blog
airedale is offline   Reply With Quote
Old 01-11-2008, 11:28 PM   #5
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Could you guys explain more what axles are so accident prone?
I am restoring 1965 Safari, that I am pretty sure is on original axle. Shall I worry?
Thanks for any info.
Kajtek1 is offline   Reply With Quote
Old 01-12-2008, 06:13 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Kajtek1 - Tired axles are harmful in a number of ways but this report relates to the lower capacity axles used on the smallest Airstreams of that period: http://www.airforums.com/forums/f437...ion-29429.html
5 meter Langford Nahanni
Old 01-12-2008, 08:08 AM   #7
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Kajtek1- Please consider changing out your axle. It's definitely a "peace of mind" issue. I had mine changed out last summer and the difference is amazing. Had new shocks installed at the same time. The coach now sits level and definitely a little higher. It literally glides down the road and I do have an enormous peace of mind since completing that task.
I would have done the work myself (with some help) but had a knee replacement this last year and was recuperating from that. I took her to the Airstream Dealer in Colorado Springs and they did an awesome job.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 01-12-2008, 08:20 AM   #8
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Yes, please include a new axle in your budget. At best, your existing axle will be marginal.
To clarify: The snapped spindle syndrome does not seem to apply to the larger axles, such as the one under your trailer. However, a new axle with new brakes makes a world of difference in the long run. You should be able to get one installed for under $ 1000.00
Uwe
www.area63productions.com
Old 01-12-2008, 10:04 AM   #9
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I actually replaced my axle because it had lost it's 'bounce' and was giving the trailer a bone jarring ride. The new axle lets the trailer just float along behind. It was worth it for that alone.
Then I met someone who's spindle had snapped, leaving them looking for a repair shop in Guatemala or some other far away country, and after hearing her story I was REALLY glad I had done it!
So do yourself a favor and budget in a new axle. The old one is 43 years old, and your whole investment is riding on it.
Stephanie
Old 01-12-2008, 10:08 AM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Wow. Makes we want to replace the axles on our 67 sooner than later.
And I DO know spindle failure. The left-front spindle on our 1948 tractor broke off clean while I was clearing snow last week. Not a difficult repair (new spindle and associated bearings/sleeves), but a tractor wheel falling off at 3 mph is a bit different from one falling off an Airstream.
Lynn
WBCCI 21043
Old 01-12-2008, 10:44 AM   #11
eubank
Spindle failure on your 67-30 footer, is not impossible, but certainly not very likely.
The rubber rod failure in your axles, at this point, is a guarantee, since the composition of the rubber was incorrect, from 1974 and older.
When the rods are gone, bottoming out will happen, which can cause spindle failure as well as damage to the frame, shell, etc.
Old 01-12-2008, 11:18 AM   #12
Kajtek1's Avatar
1965 22' Safari
Orinda , California
$1000 is way more, than I paid for whole trailer
Thanks for the response. Now I know that my axle is "not the one". At present I have one side with wheel and drum removed and the spindle is about the same size I have on my F450. I drove the trailer on original axle and tires (!) short distance from my neighbor, while the trailer had about 4 tons of books inside, so that was a good test.
Don't take me wrong, I might change the axle because of rubber parts in it in the future, but at present I am planning to use the trailer as storage on my construction site and don't even know if I'll tow it on the freeway.
Old 01-12-2008, 01:30 PM   #13
Block the trailer up, to remove most of the weight from the axle, since it's not going to move.
In that way, you won't make the axle any worse than it possibly may already be.
Old 01-12-2008, 05:08 PM   #14
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
eubank
Ah, good! We've already got plans to replace the axles, but it's going to have to wait until we can make it to California. The axles are marginal now, but not entirely shot, by my measurement.
Lynn
WBCCI 21043
caravel
Caravel Axle Replacement Melody Ranch Axles 19 02-14-2007 10:08 AM
Rear Axle Bearing Failure jking Classic Motorhomes 14 12-23-2006 04:32 PM
What should a person do with a Caravel axle? fun2bethad Axles 27 09-02-2006 09:41 AM
What should a 65 Caravel with a new axle go for? fun2bethad Trailer Values 9 10-11-2005 03:57 PM
New axle for a 1965 Caravel C Johnson Axles 1 02-23-2005 03:10 AM
