Old 01-16-2008, 10:30 AM   #29
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Hi Action,
Thanks for your thoughts. I was just typing out loud of ways to get the message out to a broader audience, and as you point out, wondering if it even needs to be.
It is not intuitive to a lot of folks and particularly new RV'ers that beyond replacing bearings, tires and brakes that the axle itself would be suspect. Hopefully they will take the time to do some research on the net.
Take care,
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 01-16-2008, 10:52 AM   #30
Originally Posted by safari57
Hi Action,
Take care,
Barry
Unfortunately, newer members don't usually look up old posts.
Therefore, some subjects need to be repeated every so often.
There are two tests for torstion axles.
The first is visual, and the following teaches a person how.
Dura Torque Axle
The second and equally important test, is to jack up one side of the trailer, and observe how much the tire drops from it's loaded position.
The tire should drop about 3 inches or more.
If not, then the rubber rods have to some degree solidified, which says the axle is bad.
Lastly. all torsion axles, in time, will take a set if not used every year or so.
There are many 30 and 40 year old trailers, that still have acceptable axles.
Rubber must be exercised somewhat frequently, if not, it will lose it's memory.
caravel
Caravel Axle Replacement Melody Ranch Axles 19 02-14-2007 10:08 AM
Rear Axle Bearing Failure jking Classic Motorhomes 14 12-23-2006 04:32 PM
What should a person do with a Caravel axle? fun2bethad Axles 27 09-02-2006 09:41 AM
What should a 65 Caravel with a new axle go for? fun2bethad Trailer Values 9 10-11-2005 03:57 PM
New axle for a 1965 Caravel C Johnson Axles 1 02-23-2005 03:10 AM
