Old 11-06-2011, 06:23 PM   #1
one of those
Gringo's Avatar
2011 27 FB International
'03 F250 PSD , Airstream summers, Catalac winters
Can one axle take the weight?
If I wanted to change all four tires while the trailer is in storage, can I take them to the dealer two at a time, leaving the trailer sitting on one axle and the tongue jack for a couple hours at a time?
This is a 27FB with dual axles, lightly loaded. Probably 6,000 lbs.
A Blog from the Devil's Triangle
http://2gringos.blogspot.com/
Gringo is offline   Reply With Quote
Old 11-06-2011, 06:48 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Yeah. Don't think you'd have any problems for just an hour or two. You can always keep the weight on the jack or jack stands too.
Lance
Top is offline   Reply With Quote
Old 11-06-2011, 06:57 PM   #3
withidl's Avatar
2002 31' Classic
Houston , Texas
If you had a flat on the road, it is OK to just remove the flat tire, throw it into the vehicle, and proceed at a reduced speed to a repair facility on three wheels; so a static load for a while should be no problem at all.
withidl is offline   Reply With Quote
Old 11-06-2011, 06:57 PM   #4
1981 31' Excella II
New Market , Alabama
Why not get a couple of floor jacks and jack stands. Or a couple of hydraulic bottle jacks. I took all 4 of mine off at once with a couple roll around floor jacks but two of any type jack will work or one if you have jack stands. Just don't get underneath it unless you have a jack and a jack stand for safety. Yeah, the axel will take the load for a short period of time if you want to do it that way.
Perry
Old 11-06-2011, 06:58 PM   #5
It's not so much weight on the axle for that short period of time, but on the two remainng tires.
You would be much better off jacking up one side of the trailer and taking those 2 tires to the shop.
Then you would not overload anything.
Old 11-06-2011, 07:20 PM   #6
one of those
Gringo's Avatar
Would that take two jacks? I've been thinking of adding a small bottle jack. Problem is that every tool I buy for it has to live in the trailer with us. Weight builds up. As a sailor and a pilot, A locker full of heavy iron junk is anathema to me.
Old 11-06-2011, 07:46 PM   #7
Trex's Avatar
1981 20' International
Shasta Lake City , California
Mr. MacGingo....you can rent jacks, I think there's an app for that.
"Sometimes you eat the bear, and sometimes, well, he eats you." -the Stranger-
Come and see me at: http://www.airforums.com/forums/f185...-71804-60.html
Trex "Airstream Nomad"
Trex is offline   Reply With Quote
Old 11-06-2011, 08:11 PM   #8
Splitrock's Avatar
Sioux Falls , South Dakota
I jacked my trailer up and took all 4 wheels to the tire shop together. Very easy and done in one trip.
Old 11-06-2011, 09:41 PM   #9
Goal15's Avatar
Dallas , Texas
Gringo:
Have to concur with Andy on this one. I used the bottle jack from the tow vehicle and it worked great. When I bought new tires I took two at a time to the tire shop to get them changed out... very small parking lot precluded me taking the AS to the tire shop.
Dana
Goal15 is offline   Reply With Quote
Old 11-07-2011, 04:15 AM   #10
one of those
Gringo's Avatar
Well it makes me nervous as heck that you guys don't feel the trailer can safely sit on two tires for any length of time. So two simultaneous blowouts would be the end of life as we know it?
I hadn't even though to look to see what the weight rating on the tires are. And of course now the trailer is not accessible to me to go look.
But can you do it with just one jack? You can raise two wheels off the ground with one jack? Is it under the frame or one of the axles?
While I think I understand what an "app" is, I am not about to buy an expensive telephone in order to change a tire. Bah. Humbug. Newfangled foofaraw.
Old 11-07-2011, 04:22 AM   #11
1981 31' Excella II
You never ever ever want to put a jack under the axel. The best place is between the two wheels. There is a vertical flat plate that the axels are attached to. Anywhere along that plate is good but between the wheels is better. Make sure you don't miss and hit a shock mount and bend it like some PO or garage monkey did to mine. Yes you can lift one whole side off the ground at that location. You can put a jack stand along that plate as well. I had to jack mine off the ground with my Excursion OEM bottle jack to adjust the brakes at a rest stop and it worked fine.
Perry
Old 11-07-2011, 04:42 AM   #12
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
2 weeks ago I replaced the 4 backing plates 1axle at a time. Got the front axle all buttoned up and drove it up on blocks. While removing the old plates I sprained my wrist and she sat like that for a week til my son could finish the job. Everything seems OK. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 11-07-2011, 04:52 AM   #13
one of those
Gringo's Avatar
Thanks for the input.
This leads me into another question. Is anyone replacing the stock setup with larger diameter wheels and tires? We are planning to park this in the middle of some property, at a spot about 800 ft. from the nearest dirt road. Thru a little ditch, across a couple rolling meadows and down into a ridge between two draws. There is no road there and I will need to Bobcat a little terrain remodeling for the last 50 yards of it. I could use some more ground clearance.
The tracks here are from the electric company's F-150 4x4 truck there. Our little rental SUV scraped gravel. I imagine the tandem axles will help, but still wonder about the pans etc. Ground clearance would be good.
I did buy a little e-tool and mellowed that ditch out a bit, but not enough for 14 ft. of trailer belly on each side.
I'll be Bobcatting this end smoother, along with the far end where we are going to park it, but don't really want to cut a long driveway across the meadow. It self-heals if we don't. I like being able to see if it's been driven on lately. Call me Hiawatha. We plan to spend a good part of the summer based at our own private one-RV park here at 7300 ft. and then take to the road in September and October when school thins the herd. Back in storage by November. Each year. This is still part of a bigger plan in the making. Still a lot of holes to be filled in (yuk yuk).
Old 11-07-2011, 05:06 AM   #14
dznf0g's Avatar
Oswego , Illinois
Take some boards with you and "fill" the ditch. Used to do that all the time with logs when four wheelin'.
-Rich-
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
New axle for 1969 Caravel scottwtalley Axles 10 12-17-2011 08:01 AM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 07:46 PM
