Old 05-25-2009, 04:23 PM   #1
1965 24' Tradewind
Warner , New Hampshire
Can '65 axles still be good?
My 1965 axels still seem to be good. Is this possible? When I trailered it home it road smooth and steady with no bouncing at all. The torsion bars are all in a downward position. Is it just wishful thinking on my part or can these actually still be good? The original owner used it at a lake and it was on blocks but I'm sure it wasn't that way forever.
If I do need to replace them what will be the easiest to install? I have read some threads about using OEM axels. This way I won't need to do any drilling and welding.
Brian
briheath is offline   Reply With Quote
Old 05-25-2009, 04:28 PM   #2
Brian
Brian.
The axle could be good, as a rarety.
Read the axle article in Airstream Central, so that you can check the axle out with the other test, other than looking at the torsion arm.
Old 05-25-2009, 06:52 PM   #3
1965 24' Tradewind
Thanks Andy
I read your article in airstream central and it explains the inspection process very well. When my trailer was all together I still had a positive angle on the torsion bars. Can this inspection still be done with the body off the frame? On will it be too light? Thanks again for your help.
Brian
Old 05-25-2009, 08:20 PM   #4
Thanks Andy
Brian
With the shell off, the torsion arm position would be artificial because of the lack of weight.
However the test to determine the condition of the rubber rods, by jacking up one side, and watching for that ball park 3 inch drop in the tire position, would still be very valid.
Old 05-25-2009, 08:46 PM   #5
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
On a 65 with OEM axles you will have to drill 3, 1/2 holes on each side of the axle. You will also have to weld on your shock brackets. I just put a set of Andy's axles on my 1967 Tradewind, the fit was excelent, and his service is supurb! Adios, John
Diesel1 is offline   Reply With Quote
Old 05-31-2009, 06:58 AM   #6
1965 24' Tradewind
Do I need to cut my existing shock brackets off the frame and then reweld them in a different location? How involved will this be? It doesn't sound to bad since it seems like many many people have to do the same thing. Just trying to save myself so extra work if possible.
Brian
Old 05-31-2009, 07:31 AM   #7
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I am in the proccess of installing pair of new axles from Inland RV. Today I have a neighbor welding the shock brackets on for me. One original axle has been removed. I am taking pictures as I go to post soon. Stay tuned. Don't touch that dial.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-31-2009, 07:35 AM   #8
FreshAir's Avatar
1966 24' Tradewind
Brian
If you buy your new axles from Andy everything that is needed is included, new shock brackets down to new lug nuts. Of course I getting new baking plates w/new brakes and drums.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 05-31-2009, 08:02 AM   #9
Neil
We also include "grade 8" mounting hardware, and an axle manual at no charge as well.
Old 05-31-2009, 12:27 PM   #10
1965 24' Tradewind
Thanks Lizzy I look forward to seeing the progress.
Brian
Old 06-04-2009, 12:17 PM   #11
1965 17' Caravel
Creston , Iowa
66 caravel axles
where is the best place to buy a kit to replace the axle in my 66 caravel ,I see andy's is listed ,is there a site or a phone number to call them or maybe inland rv ?? please list if there is ....Thanks Dave Rooker
rook440 is offline   Reply With Quote
Old 06-04-2009, 12:52 PM   #12
Our toll free phone number is 800-8777311.
Old 06-04-2009, 01:11 PM   #13
toddster's Avatar
1967 20' Globetrotter
Campbell , California
Is there any way that the axle on a '67 Globetrotter could still be good? Both of the torsion arms are still showing a good downward angle when fully loaded.
Is there an easy way, aside from "does it look old", to tell if my axle has been replaced? This trailer lived on the coast for a few years so surface corrosion is not a good indicator.
toddster is offline   Reply With Quote
Old 06-04-2009, 02:28 PM   #14
FreshAir's Avatar
1966 24' Tradewind
As I posted earlier I am half way done with replacing my tandems. Our Trade Wind had some slight downward angles to them so I was hoping to postpone the axle replacement. However, a recent return trip on I-80 that has a really rough stretch tossed everything out of the rear bath sink and wardrobe. In removing the bolts of the axles 2 have to exit out behind the tortion arm. I suppose one should be able to pry the arm up or down some to give clearance for the bolt to slide out. One out of the four bolts I could do that but three would not budge enough. The rubber is as hard as iron with NO give. I had to cut the bolts to get them out. Moral; old tortions may 'look' OK but they ain't cushioning any bumps.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
AAA vs. Good Sam? jambie Insurance & Claims 39 09-30-2011 09:36 PM
