Old 10-02-2012, 09:22 AM   #1
1962 19' Globetrotter
Vancouver , British Columbia
Buying new axle in Canada
Hey guys
Who here up north has bought a new axle for the stream? I've gt a 62 globetrotter and need to replace it with a much stronger one
I'm I. Vancouver bite oil like to find up here if possible
Stupidnoob is offline   Reply With Quote
Old 10-02-2012, 09:40 AM   #2
Originally Posted by Stupidnoob View Post
Hey guys
Have it shipped to a friend in the USA, and pick it up from them.
Many Canadians do that.
Old 10-02-2012, 09:49 AM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
I have used this outlet in the past with good results. What you will pay extra for Canada shipping would offset any costs involved. And the border crossing is not a big deal.
"115 1st St, Sumas, WA 98295-9674http://www.myshiphappens.com"
Dave
Old 10-02-2012, 03:09 PM   #4
Well I've got a mailing address to Bellingham on the other side to make things easier
I need to find measurements for a 62 globetrotter... Time to scour the interverse to try and dig it up... First timer here
Old 10-02-2012, 04:53 PM   #5
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Original was 3200#, 22 1/2 arm angle, 57.875" outside to outside mounting bracket dimension and 73.75" hub face dimension, if you go with a Dexter you'll have to start at 3800#, (you can go up to 6K with this axle), #11 tube, and enlarge the existing notches in your mounting bracket, when going to the bigger tube the original Henschen axles increased the hub face to 75 1/2". You'll either want to stay with the original low profile bracket, or if you want more height you can ask for the high profile bracket, giving you 1" more and possibly increasing the arm start angle to 35
IMO.....the Dexter is a much better product than anything else out there.
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 10-02-2012, 05:07 PM   #6
Hey guys
The original axle was 32oo pounds.
In 1965 it was changed to 4000 pounds.
Having the serial number available is a great help when ordering an axle.
Also, stay with 12 inch brakes.
You can upgrade them to self adjusting brakes.
A higher starting angle will make it easier to hook up to your tow vehicle.
Buying in Canada (BC) and bringing it back to the US? day tripper Local Regs & Licensing 9 02-07-2013 10:00 AM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
canada customs policy on buying airstream in states annw Shipping & Export/Import 32 06-01-2007 09:41 PM
