Old 08-11-2008, 05:57 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
Bushings
What is the best way to remove the steel bushings from the frame and the eye ends of the leaf springs. I have spent hours and have removed only 2. There appears to be 2 bushing separated by rubber, very hard to remove.
toastie is offline   Reply With Quote
Old 08-11-2008, 06:03 PM   #2
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
We used to use a torch, to burn the rubber out. Nasty and stinky but effective on car leaf springs.
LJH is offline   Reply With Quote
Old 08-11-2008, 06:05 PM   #3
toastie's Avatar
1955 22' Safari
Thanks...........I'll try that tomorrow
Old 08-11-2008, 07:08 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you want to try a less flammable method, you can get an air hammer with a blunt end, and drive it out with that. Hearing protection strongly suggested. If that doesn't work, you can always try the "hot wrench".
Old 08-11-2008, 07:10 PM   #5
Images: 59
Ditto the torch. Don't get any of the stuff on ya. Afterwards, use a cold chisel to split the outer shell bushing. Not an easy job, but needs to be done.
Old 08-11-2008, 07:11 PM   #6
Well Preserved
1993 21' Sovereign
I'm just concerned with that 53 year old plywood a few inches above the bushings. It would be very dry, and ignite easily.
Old 08-12-2008, 05:23 AM   #7
toastie's Avatar
1955 22' Safari
The shell has been rasied and the floor removed.....thanks
Old 08-12-2008, 05:15 PM   #8
toastie's Avatar
1955 22' Safari
Mark
Between the torch and air impact hammer I easily removed outer and inter bushings. The eye on the leaf springs now measures approx 1 1/4" and also the frame. I was thinking of using steel bushing on the frame and bronze bushings for the leaf eyes, both I.D. of 9/16" and my question is, do you know where I can buy them?.........thanks
Steve
Old 08-12-2008, 06:21 PM   #9
Images: 59
Steve,
Are you going to use solid bushings, why not replace with rubber lined bushings like the original?
Old 08-12-2008, 06:41 PM   #10
toastie's Avatar
1955 22' Safari
Steve,
This is new for me, how hard is it to install rubber lined compared to the solid bushing.
Old 08-12-2008, 07:11 PM   #11
Images: 59
I don't recall exactly how I did it, but it involved a large 5/8" bolt for a jackscrew, and some large bushings, or a large socket, to make up the difference in length between the inner serrated bushing, and the outer sleeve.
You want to be pushing on the outer sleeve, not the inner sleeve. I'm sure an arbor press would have been easier.
The nice thing about the rubber bushing is that the outer sleeve is thin enough that it will conform to the ID of the spring eye. Also, if the front hanger is just a half degree off perfect, the rubber will still let you swing the leaf pack left or right a half inch to align with the rear hanger.
Old 08-13-2008, 05:28 AM   #12
toastie's Avatar
1955 22' Safari
Thanks very much, will go with the rubber bushings, where did you buy yours, went to the net and couldn't fine them.
Old 08-13-2008, 05:55 AM   #13
Images: 59
Got them from Standard Spring of Minneapolis. Their part no. is RB1, and they were $7.39 each. I don't know if it is a stock item. That was 5 years ago. Phone is 800 356-3897.
Try your local full service spring foundry first.
New Sway Bar or Just New Bushings? streamlean General Motorhome Topics 48 09-25-2007 10:12 PM
