Old 09-06-2016, 02:01 PM   #1
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Bushings
I want to replace the suspension bushings and install greaseable bolts in my 1957 22' Custom, but I can't find the parts. Anyone know what the correct parts are and where to find them?
DDickey is offline   Reply With Quote
Old 09-06-2016, 02:13 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Best way, pull the old bearings and visit NAPA. Never heard of a a "greaseable bolt".
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 09-06-2016, 02:44 PM   #3
DDickey's Avatar
1957 22' Custom
Lago Vista , Texas
Greaseable bolt
Hey AWCHIEF, not the bearings, but the leaf spring and shackle bushings. Newer shackle bolts have zerk fittings on the end so you can grease the joint. I don't want to burn the old bushings out without knowing that I can find the right ones.
Old 09-06-2016, 03:49 PM   #4
AWCHIEF's Avatar
Images: 33
Sorry about that.
MICHAEL
Old 09-06-2016, 09:53 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The answer is still the same.
Pull the bolts and find a shackle to match. That age of trailer has parts that are no longer in a book. And many of the parts are generic trailer parts not necessarily specific to Airstream. The issue is they are generic to really old trailers.
>>>>>>>>>>>>Action
Old 09-06-2016, 10:34 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My '46 Dodge pickup had grease able bolts on the shackles. It is nothing new. It's just more expensive. Need I say more?
Contact a place like Redneck Trailer Supply or someone with expertise in trailer suspension. They should be of more help than an auto parts store. If you don't have the year, model, engine size and whether or not it has air conditioning you can't buy a turn signal bulb at an auto parts store. Even worse, try buying anything for your TV at the dealership without the VIN number.
Time for new Bushings. Where to Purchase them? John H. Airstream Motorhome Forums 6 06-13-2011 04:30 PM
P30 swaybar bushings for 81 Excella 280 silverback Classic Motorhomes 12 09-16-2009 08:01 PM
1965 Caravel door bushings and pin... VintageTin Doors & Locks 1 07-31-2009 02:31 PM
Bushings toastie Axles 12 08-13-2008 05:55 AM
New Sway Bar or Just New Bushings? streamlean General Motorhome Topics 48 09-25-2007 10:12 PM
