Old 03-02-2008, 03:55 PM   #1
1966 26' Overlander
1995 36' Cutter Bus LE
Largo, Florida , Florida
Andy: I have a 1995 36' Cutter LE and am currently stranded in Port Lavaca, Tx. Our rear axle seal on the curbside rear axle failed resulting in a broken axle. We had the MH towed to a truck repair company and they are trying to locate a refurbished axle to replace the Dana rear end with a 5.35 rear end. We have been searching for over a week to no avail. There seem to be many available with a 4.10 rear end. I am reluctant to move in this direction---Any advice???
brodjeaw is offline   Reply With Quote
Old 03-02-2008, 04:12 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Brod...
Sorry to hear you're having trouble on the road, always stressful.
While I can't assist, I do recommend you start a "New Thread" in the Motor Home section and title it HELP.
I think you will get a better response and visibility.
Best of luck,
Michael
ArtStream is offline   Reply With Quote
Old 03-02-2008, 05:30 PM   #3
We cannot help you with the drive axle, or any of it's parts.
We can help you with the tag axle.
Old 03-02-2008, 08:06 PM   #4
1966 26' Overlander
Broken Axle Seal with a broken axle and rear end
Andy: We have a 95 Airstream MH Cutter Le Gas 36'. Axle made by Dana and gear ratio is 5:35. Chassis is by Ford. Truck repair shop is Fort Lavaca, Tx has been searching for over 1 week for refurbished rear end with no luck getting the right gear ratio. 4:10 ratio is available.
Any thoughts???
Jean Brodeur
Old 03-03-2008, 08:29 AM   #5
Any thoughts???
Jean Brodeur
We do not carry "drive axles," or any parts for them.
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Midwest Hi Way Drive In firebird Boondocking 10 05-28-2007 10:58 AM
Engine/drive repair places? '79 Moho dye904 Mechanics Corner - Engines, Transmission & More... 5 11-11-2005 05:46 AM
Broken Axle on 2004 Int'l dkekrksk Axles 26 07-04-2005 09:27 PM
Drive vs Over Drive joshua32064 Tow Vehicles 10 10-17-2003 01:25 AM
