Old 04-21-2006, 09:37 AM   #1
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
Question Brakes, Shocks, Bearing?
Hey ,I was wondering if someone new the part Number for the Brake,Shocks,and bearing.I would like to start replacing two at a time.For a 75 31ft A/S sov.I hoping i can do one a day .Am very picking and i like to take my time.I would of ask for but my owner manual.Tells me how to do it but i cant find the sizes or part number .Can any help with this?
Angel73 is offline   Reply With Quote
Old 04-21-2006, 08:23 PM   #2
1960 24' Tradewind
santa barbara , California
Hello Angel73,
there are different seals and bearings for different year airstreams and axle sizes etc. The best and most certain way would be to take one wheel and drum assembly off . you could take the bearings and seal to your local rv store and match up the parts .Sometimes the stamped numbers on the bearing s are very hard to read ,but that way you wont end up with the wrong parts .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 04-21-2006, 10:26 PM   #3
Angel73's Avatar
1975 31' Sovereign
Images: 65
Thats the problem we dont have one here at all.The closes one is 10 hr or more away and with the gas price...I cant go that far
Old 04-22-2006, 09:50 PM   #4
1960 24' Tradewind
Angel73,
True that, I hear you.Ok pull one apart ,get the # off the bearing cone and or the race,also the seal.i am sure someone here can get the parts you need or the place that is far away can order them .Call Inland RV ask for Andy ,give him your coach info ,He should be able to figure out what you need ,you can purchase as you like one wheel at a time or?The brakes are not a problem as you should have 12" drum brakes and they should be electric ,Purchase the complete assy ,best deal for your money,match it to your existing setup ,the backing plate loaded as its called .You can private message Inland RV here on the forums.Same with the shocks ,always replace the shocks! very important .
hope this helps
Scott
Old 05-02-2006, 11:40 PM   #5
Angel73's Avatar
1975 31' Sovereign
Images: 65
I'll check that out ty
The Clark Family
Old 05-02-2006, 11:43 PM   #6
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Bearing seals
Hello Angel... Try Napa.. we did and they had what we needed.. Annie
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 05-03-2006, 08:48 AM   #7
Angel73's Avatar
1975 31' Sovereign
Images: 65
Wow!
We do have one of those in town...Did you get the shocks from them too?
The Clark Family
Old 05-03-2006, 08:56 AM   #8
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
We found bearings and seals at our local farm supply place - a lot of utility trailers and horse trailers use the same parts.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 05-03-2006, 09:10 AM   #9
Your outer bearing is # LM 67048
The inner bearing is # 25580
It's not likely that you can get electric brake shoes or magnets from an auto parts store.
The grease seal could be one of two different ones.
The serial number of the trailer would answer that question.
Generally speaking, you can get your Airstream parts, from an Airstream parts stocking dealer, that makes daily shipments.
Old 05-03-2006, 09:54 AM   #10
1979 30' Argosy
shocks
Hello Angel.. We got the shocks from an Airstream dealer but hubby said he could get them from an auto parts store next time... we will be doing the new Argosy with them.. Annie
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 05-03-2006, 10:50 AM   #11
The original "horizontal shocks" that Airstream has used for almost 40 years, are not available from auto parts stores.
The Airstream shocks are an "OEM" item to them, and can only be purchased through an Airstream dealer.
Old 05-03-2006, 04:18 PM   #12
Angel73's Avatar
1975 31' Sovereign
Images: 65
ok ...Andy
Here is what she is land yacht international soverign Ser# I31-A5J-1154 G53-GD made on 7/27/1974 at the Jackson Center Ohio....Does this help?
Would you have these parts?We're not for sure the brakes are bad but we do want to replace the bearing and shocks for sure...
The Clark Family
Old 05-03-2006, 04:23 PM   #13
We stock all of those parts.
Old 05-03-2006, 04:30 PM   #14
Angel73's Avatar
1975 31' Sovereign
Images: 65
Great
Thanks Andy..i have check other price from you....for the window ,vents and door seal plus fussy stuff....they lady told me to measure them and i ....well i thought i did it right until i got a 266.95 price tag ....lol now my husband is going to remeasure when he gets back in two weeks....lol don't want to miss a good sell You guys are having
The Clark Family
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 03:37 PM
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
