Old 11-15-2012, 11:05 AM   #15
rogerdodger's Avatar
Fresno/Clovis , California
Originally Posted by overlander63 View Post
Axis through Colin Hyde will provide shock mounts pre-welded on their axles. They also use the no-hole-drilling mounts.
Good luck on hearing from Colin! I left 3 emails, and 3 voice mails, he never returned any of them. Just sayin'. IMHO
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 11-15-2012, 11:51 AM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The last set of axles I received from Colin are Axis. They did have shock mounts, but required all 4 mounting holes to be drilled. The trailer is a mid '60's model with tandem axles.
Old 11-15-2012, 12:01 PM   #17
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Originally Posted by rogerdodger View Post
I have been researching axle upgrades. I have been told that Dexter will not supply axles with the shock bracket, you need to have them welded on at your expense, no matter who you get them from. Axis I cannot answer for.
Not entirely true. I bought Dexters from Carolina Wheel and Rim in Charleston, SC. I think they built the axles in Atlanta. The guy called them after I had placed the order, they said that they had the pattern for the Airstream shock mounts, and they welded them on for free when they built the axles.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 11-15-2012, 12:07 PM   #18
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have never had a problem connecting with Colin. He either answers the phone or gets back to me quick time. Same with Emails. I'm just sayin'.
MICHAEL
Old 11-15-2012, 01:19 PM   #19
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Ready to go
Originally Posted by Mixter View Post
Looking for some direction... I see some threads of people having to re-drill the mounting holes and measure/ correct for out of alignment.. Also, see that some have to weld on shock mounts...
I dont want to do any of that if I can help it. Looking for a direct replacement that I can bolt on and go. Is there anything sold ready to go?
Any help is appreciated.
Thanks!
Micky
The best deal can be measured in many different ways. We all have our own ideas of what is "best".
As previously stated above, Axis axles from Colin Hyde can be ordered with the older Henschen brackets and shock mounts already welded on. No welding or drilling required.
If your trailer is out of alignment, you will need to address the issue regardless of which replacement axle manufacturer or supplier you chose. Good luck and hope all works out well for you.
Lance
Top is offline   Reply With Quote
Old 11-15-2012, 01:27 PM   #20
Mixter's Avatar
1976 27' Overlander
As always- great info here. Thanks everyone!
Mixter is offline   Reply With Quote
Old 11-15-2012, 08:44 PM   #21
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Just to go back to the main question, does some one produce bolt on shock brackets?
Silverflames is offline   Reply With Quote
Old 11-15-2012, 08:58 PM   #22
No.
Old 11-15-2012, 09:06 PM   #23
Not sure when you got your axles, but I got my info from Redneck trailer( a Dexter axle dealer), Toscano RV( an airstream dealer), and Inland RV( an airstream dealer), as of beginning of 2012, Dexter no longer welds shock brackets on their axles. If you have current info, I would like to hear about it, would save me and others the cost of welding brackets from old to new axles.
Thank you,
Roger
Air# 29488
Old 11-15-2012, 09:08 PM   #24
I have not heard of any, but maybe someone has. Anybody??
Roger
Air# 29488
Old 11-15-2012, 09:27 PM   #25
Central , Mississippi
Thanks!
Micky
If you couldn't guess...there is a big dust bowl over Airstream replacement axles...
As best I can tell...(with some experience here)
Henshen made you'r axle and they are out of business...
Axis bought their stuff, got bought out by a bigger company and will make a replacement axle
Dexter got the Airstream OEM business several years back and they have hundreds of sales points but none of them let you walk up and say 'I want an axle for my XXX Airstream...' without some measuring
Any of them will install shock brackets if you wade thru the muck and figure out the 'code'
Driilin' out a hole is one of the smallest details but a huge sales detail...
Why would anyone buy 12,000 lbs brakes for a 4,000lb trailer? anything over (12V*4000/12000=) 4 volts (33% of your controller resolution) on the brake controller will lock up... (ask a trucker what they have to do for an empty trailer to keep the tires from smokin' flat spots)
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-15-2012, 09:48 PM   #26
Well said HiHo!!
Roger
Air# 29488
Old 11-16-2012, 05:40 AM   #27
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
No, they are all weld-on, or already welded on.
Old 11-16-2012, 07:01 AM   #28
Thank you,
We supply new shock brackets for the Dexter axles.
