Old 07-14-2009, 05:34 PM   #29
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Originally Posted by stufarmer View Post
The Tire in the top right clearly shows an internal tread seperation. Regardless of alignment wear, it is impossible for an alignment problem to cause a single bald spot in the center of a tire. Alignment wear is a consistant wear pattern or feathering. The only way a tire can be bald in only one spot is by a brake locked up to the best of my knowledge.
During this process I did adjust the brakes. It used to pull to the left some, and that brake was the tightest. I think there were a lot of issues taken care of today. While I was taking the trailer back to the farm (2.5 miles and 2 stoplights) it seemed to stop straighter. I could not really tell if it pulled better. We will get it out on the road next weekend for a 230 mile round trip weekend and I think we will tell then. Thanks .
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 07-14-2009, 06:16 PM   #30
Baltimore , Maryland
Turn right and see where the road takes you... that is too short a tow to see how it is doing.
axle
bent stabilizer funkill Jacks, Stabilizers, Lifting and Leveling 13 03-28-2009 06:48 AM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
axle bent? air66stream Axles 1 10-05-2007 04:12 AM
Bent Wheels jim8860 Mechanics Corner - Engines, Transmission & More... 2 03-08-2006 07:17 PM
Bent (?) Door Jabba Doors & Locks 1 10-26-2002 10:44 PM
