Old 07-27-2007, 11:59 AM   #29
Dexter axle dealers/distributors/service centers
California has listed 17 company names.
15 are dealers.
7 do service as well.
2 are distributors.
We all know that Dexter is number one.
We all know that Alko/Hayes is number two.
We all know that Henschen is some other lesser number.
That has been stated a number of times.
NOW,can we got on with the real purpose of this site, and make positive contributions towards the Airstream community and it's product owners.
Granted, to some, sitting back and being a fault finding expert, offers little to the best interests of forum members.
All it does, is waste space and create negative controversy.
According to a select few, AIRSTREAM must have been very stupid for using Henschen axles for over 40 years. According to them, all other torsion axle manufacturers build cheaper products than Henschen. Of course, they fail to mention quality. So why did Airstream chose Henschen, that costs more? Easy answer. Airstream insists on top quality components.
The recent change Airstream made to Dexter, has nothing to do with price or quality, but does have to do with Corporate bickering.
By the same token, Dexter and Alko have a very limited background with the Airstream products. They certainly are far from being an expert, especially when they insist that 10 inch brakes are ok on a 31 foot Airstream. HUH???
There are several other lesser know torsion axle suppliers, that are even less knowledgeable about the true workings of a monocoque shell. They may be axle experts, but that is as far as they can go.
There are a couple of torsion axle manufacturers that will not build an axle for an Airstream product, simply because they don't want to get involved with the changes necessary in order for their axles to fit properly, or have the Airstream type quality of construction.
Old 07-27-2007, 12:45 PM   #30
1976 24' Argosy 24
Milford , New Jersey
Andy, I agree, let's get on with the true purpose of the forum. It would seem the issue of axles, as simple as they may be, evoke strong opinions on both sides. Your a good guy, I've had good expierience dealing with you and your staff. You sell a good product. As the sole supplier of Henschens, I believe that some will always view you as a bit of a target. Don't let them get you down. When my time come to buy, I will do my research and decide what I feel is the best product for my budget and ability.
Gkiesel is offline   Reply With Quote
Old 07-27-2007, 01:23 PM   #31
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
alright folks. [mod had /on]
lets take a deep breath.
that is all.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-27-2007, 03:15 PM   #32
1972 25' Tradewind
Madison , Wisconsin
Bolt in.
Originally Posted by Gkiesel
Nice Job! Which brand of Axle did you use?
As Andy said they were Henschlen and a direct bolt in. They aligned without adjustment.
I supplied Andy the trailer model and plate info. We talked about how I loaded and traveled, that related to weight ratio. I travel heavy (full water tank and heater-not black water though)...it keeps the center of gravity lower.
I had additional questions for Andy about doing it myself. I was a bit shaky about it as I am somewhat disabled by a few spinal surgeries knees etc. After my conversation with Andy I felt it was something to try myself. It went smoother than I thought it would go. It is sort of another renovation feather for the cap! .
I did check out Dexters as I had used them many years ago on a cargo trailer. I think they make an excellent product. The Henschlen is made for the Airstream and required no modification, thus less chance of an error and no drilling holes that may cause alignment adjustments to be made. after modification costs the numbers were not all that far apart and (in my mind!) did not justify were not worth it when I could do a simple bolt in.
Andy went through the entire procedure with me. The shipping was not too bad though I do not remember what it was. The axels were drop shipped from Ohio, saved quite a bit there. While I will not argue the merits of one or anothr with the axel experts, as a shade tree mechanic type I feel the route I took gave me the best results and the highest value for my $$'s.
Smokin Camel is offline   Reply With Quote
Old 07-28-2007, 05:57 PM   #33
Originally Posted by drag'nwagon
I was pretty shocked as well that they were out that far.
I am not concerned so much with the cost of this as much as I am the rhetoric of balancing and then not offering tighter specs on new OEM replacement product specifically for AS. As I said I am not concerned with what I got as I had planned to do this anyway and hold no bad feelings against anyone, I am a manufacturer and I get it, but has anybody checked quality lately?
You mean to tell me this is the Airstream "OEM" supplier? NO WAY would I accept that from an OEM. The amounts that you were off by were astronomical for the price you paid.
When I had the running gear checked on the Minuet, after the axle/drum replacement, I was out by a maximum of 3/4 oz.
As for checking quality, here at GM Powertrain, we have error-proofing. This means that each and every process is checked at a rate of 100%. Every machined, ground, turned and assembled part is checked. Sure, things get by but your quality issue with your drums is no where near the scope that we have here at the plant. We make 1,500 transmissions/day. How many axles did the "OEM" ship?
Boy, am I glad I went the way I did on my axle/drum replacement. That also tells me where I am going to go for the Sovereign too.
Anon is offline   Reply With Quote
Old 07-28-2007, 07:36 PM   #34
Images: 59
Originally Posted by pattersontoo
As for checking quality, here at GM Powertrain, we have error-proofing. This means that each and every process is checked at a rate of 100%. Every machined, ground, turned and assembled part is checked. .
I've found that almost every vendor I use has some form or other of error-proofing. It's not just GM and GE and Medtronic anymore, it reaches down to the smallest manufacturers.
You need to have process qualification and validation if you are going to compete with asian manufacturers. Otherwise, you might as well sell junk like China.
Old 07-30-2007, 10:23 AM   #35
Exactly my point.
Error-proofing is so common nowadays it is surprising that something like this is allowed to happen.
If we wind up with one transmission that is missing even a part tracking stamp on a certain component, the whole shipment is quarantined.
No one is playing games with process control and product tracking any longer. It is no laughing matter when it comes to competing with the highly inferior, yet half the cost, Chinese manufacturers.
When I hear of an American OEM letting something like this slide by them it ticks me off.
Dave-I would not have been so forgiving.
I guess you have to be aware of what you are getting and use your own good judgment when replacing anything on your Airstream.
I myself would have gone right to the purchasing source and demanded satisfaction. I do not care who made the drums. I just know who I bought it from. When you buy a new GM vehicle and you have a problem with a tire you still go back to the GM dealership, not Goodyear.
Dave-be sure to show me your, "no modifications required" replacement axle at the rally this weekend. I cannot wait to see it!
Old 07-30-2007, 10:43 AM   #36
Exactly my point.
The time has come to post the Axis Henschen comparison, in our web site, and stop the unjustified negative bashingof Henschen.
Laboratory tests more than prove that.
They did that so well, that they quit making axles for Airstream and Argosy trailers.
Old 07-30-2007, 11:02 AM   #37
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Easy Does It Fellas
This is what is so good about the airforums.
You guys believe it what you say so very much. However, sometimes you do not see that the other guy has the right to an opinion, even if he is wrong.
My wife says I am wrong a lot. Even God says I am wrong most of the time.
But I still like Airstreams, respect you guys and appreciate the opinions on the forums.
R
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 07-30-2007, 03:33 PM   #38
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I can't find the lab tests
The time has come to post the Axis Henschen comparison, in our web site, and stop the unjustified negative bashingof Henschen. ... you find fault with anything and everything about a Henschen axle, "yet you purchased axles for your Argosy from a company that manufactured sub standard quality axles."
Laboratory tests more than prove that...
Since the moderators have neither modified nor removed the post quoted above, I have to ask:
Originally Posted by TomW
Andy, Where's the beef?
I just checked InlandRV.com, and the last new information on axles was posted June 5, 2002. Where is the comparison between axle brands located?
Tom
Old 07-30-2007, 05:46 PM   #39
Somewhere , Indiana
This comparison might have been based off of a single axle purchased from me - back in the day when I was at Axis!
Interesting note - Dexter started Axis!
Regards,
Henry
axleman is offline   Reply With Quote
Old 08-01-2007, 12:12 PM   #40
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Easy does it, folks.
We've all pretty much been over the same info repeatedly. If you do a forums search on axles, you can get all this info from other posts, without raising everyone's blood pressure.
Bottom line is, both companies make good quality products, the main difference is if you want to pay more for basically a direct fit unit, or save some money and make the modifications to the competitor's unit. And that decision should be left to the person either buying or installing the axles. They, and only they, know their limitations.
'Nuff said.
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Who made my axle? Pahaska Axles 44 07-25-2007 10:08 AM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
