Old 07-24-2003, 01:17 PM   #1
Myrjer's Avatar
Bearing Numbers
I thought I would ask just in case . I'm trying to order brake assy. for my Excella and they told me they need my inner and outer bearing numbers and the number of holes in the brake flange. I 'm on the road and will not be able to take the wheels off again to look for several days. Trying to get brake assys. ordered and shipped ASAP. Does anyone know this info from experience? The hubs are 12x2 , 5 hole 5.5 bolt circle.
( That's probably obvious but thought I better throw it in )
Myrjer is offline   Reply With Quote
Old 07-24-2003, 02:42 PM   #2
Some of your posted information is not correct for that model.
Call me at 800-8777311 and I will try to help you solve the problem.
Old 07-24-2003, 04:32 PM   #3
Myrjer's Avatar
Bolt Circle Error
Thanks Andy . I've got my son ( heaven help me ) taking the wheel off to get numbers before I call you. I had him measure the bolt holes and he says they are 2 3/4 " apart . I was going by memory and erred. So, I guess that would be a 4.75 Bolt Circle. Probably the erroneous info you refer to.
The saga continues............
Old 07-24-2003, 06:24 PM   #4
Your Excella should have 6 bolts on a 5 1/2 bolt circle.
Old 07-24-2003, 06:49 PM   #5
Myrjer's Avatar
Your Right Andy
There are 6 holes and they measure 2 3/4 " apart.
I also have the Timken bearing numbers.
Inner: 25580
Outer: LM67048
Old 07-25-2003, 07:31 AM   #6
The only question now is do you have "electric" brakes, or the "Excella Vac", which is the "disc brakes?"
Is there a large plastic housing behind the LPG bottles and below the front window?
Old 07-26-2003, 07:33 PM   #7
Myrjer's Avatar
ELECTRIC
Thanks Andy. I'm just now getting back to the forum. Yes , they are electric. Must have been converted at one time as I see where the vac lines have been cut near the wheels. The electric lines were cut too which is why I started this troubleshooting process in the first place. Once I got in the wheel I found the wiring to the magnets was burnt up. I guess now the thing I have to figure out is where to run the wiring from the wheels . One to ground block on fuse panel and one too brake line from controller? I'm also removing old AC and installing new one so I've got a lot of irons in the fire. Hopefully I can get all this labor done soon so we can start the fun stuff like decorating. :-)
Hope yours is a great weekend and thanks for your involvement with my dilemma.
Jerry
Wheel Bearing Numbers Pick Axles 5 09-27-2004 05:46 PM
Axle bearing numbers, 2003 Safari 25 freud Axles 10 11-23-2003 03:34 PM
I need numbers, Part numbers that is. thenewkid64 Airstream Motorhome Forums 1 07-19-2003 10:51 AM
WBCCI Numbers on Argosy overlander64 Our Community 2 06-26-2003 04:21 PM
WBCCI Numbers question? tiniree WBCCI Forum 2 04-22-2003 12:43 PM
