Old 05-03-2010, 07:58 AM   #1
slk
Elk River , Minnesota
Bearing greasing intervals
I have a 1996 Excella. When I pruchased it I took out the berrings and inspected them and they looked great. I cleaned and repacked them. I just went on a 3200 mile trip from MN to LA and checked them for heat every time we stopped for fuel. They never even got real warm at all.
So my question is when should I repack them again??
Steve
slk is offline   Reply With Quote
Old 05-03-2010, 08:15 AM   #2
Kevin245's Avatar
Hello Steve,
I pull ours down annually to inspect the bearings and brakes. Its a peace of mind thing for me.
Regards,
Kevin
Eleanor Roosevelt
Old 05-03-2010, 08:17 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have Lucy's wheel bearings repacked every 10,000 miles, which for us, is about twice a year. At about 50,000 miles we had Lucy's brakes replaced. At this point we also put in new wheel bearings.
Brian
SuEllyn & Brian McCabe
Old 05-03-2010, 09:52 AM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Driving through standing water it is a repack soonest trigger.
Stuck brake and excessively heated drum-wheel-hub is a repack trigger.
Any others?
Old 05-03-2010, 10:19 AM   #5
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
Engineering Design Challenge?
Few people repack automobile wheel bearings any more. We know both are not the same with different components and operating conditions and characteristics. But still, itís this an unmet engineering design challenge?
Is it impossible or too expensive to design and build trailer wheel assemblies with longer maintenance periods or MTBF (mean time between failures)?
Some I talked to said they never repack them and had no problem. But they check for over heating.
One guy said he repacks them because he has problems with them. (Maybe he isnít doing it correctly.)
I mean ĎIf we can land on the moon Ö Ö í you know the rest.
JStanley is offline   Reply With Quote
Old 05-03-2010, 10:28 AM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
10,000 miles seems to be the standard recommendation. That being said these bearings appear to me to be no different than the front wheel bearings on my 2 wheel drive TV. I have re packed those bearings twice in 500,000 miles.
I think the repack intervals are way too often unless running in water like a boat trailer.
I do use good synthetic grease, but only pack or inspect the bearings when servicing the brakes.
I have never had a bearing problem in 40 years of trailering.
When I do a walk around I will sometimes check the temp by hand or with an IR thermometer.
Some of the grease used in older trailers years ago seemed very waxy and would dry out but with the newer lubricants there does not seem to be a problem
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-09-2010, 08:09 PM   #7
tpi
Trabuco Canyon , California
I agree with Rick Davis post. That said, I just did a brake adjustment and I always shake the wheels when I have it lifted. Well... one of the wheels had about 1/3 inch runout at the outside edge of the tire. Trailer is fairly low mileage, less than 20K miles.
I pulled out the bearings, the outer bearing looked good but the inner bearing was absolutely toast. The bearings were full of grease, at this point contaminated from the extreme wear of the inner bearing. There was no sign of corrosion. The factory bearings were Koyo made in USA.
I replaced inner and outer bearings and races.
Probably a defective bearing or installation error.
tpi is offline   Reply With Quote
Old 06-09-2010, 08:31 PM   #8
r carl's Avatar
Lin , Ne
I think you just need to clean-inspect-repack when the brakes need replacement. But you need to use a high grade grease. $3.00 a tube grease is not high grade. I have 70k mi on my chev truck frt bearings and the brake pads are only half worn so it will have over 100k mi when the bearings get repacked.
Greasing bearings henw Axles 14 03-20-2010 06:16 PM
greasing bearings on 3500lb Henschen axle toastie Axles 1 06-28-2009 07:43 PM
Hensley Arrow hitch update-- greasing John Hitches, Couplers & Balls 0 04-17-2002 09:28 AM
