09-23-2014, 07:30 AM
1964 17' Bambi II
Galveston
Bambi 2 axle, wheels, & tires
Can someone please help me with what I need to order a axle from Dexter for my 1964 Bambi 2? I don't understand why this is such an ordeal. I've been dealing with this for months and I still don't know what I'm doing!
Please help!
CINDERELLA2
09-23-2014, 08:55 AM
1986 31' Sovereign
Miami
Call Inland RV or Colin Hyde with your VIN number. That is all you need to do.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
09-23-2014, 11:08 AM
1972 27' Overlander
Denver
, North Carolina
Call Colin Hyde. He has Axis axles. Best for your Trailer.
Lucky Dave, Denver NC
09-23-2014, 02:12 PM
1960 24' Tradewind
Riverside
, United States
You'll need to order a 10TF35-545E.
That will get you a #10 Dexter axle tube with 10" electric brakes and 5 lug drums on 4 1/2 bolt circle. Then you'll spec the down angle (22 1/2° was standard), then the hub face, should be 76" and the outside bracket dimension, again should be 57.875", these 2 dimensions you can check against your existing axle, finally the weight rating, you can spec anything from 2300# to 3500# in the #10 tube.
Finally you'll need to spec the mounting brackets to be installed reverse for Airstream trailer.
Your original rating should have been 3K.
You can order this from any Dexter dealer
Greg
Greg Paulsen
09-23-2014, 02:29 PM
1964 17' Bambi II
Schererville
, Indiana
I got my axles for my Bambi II from Colin Hyde. Perfect fit.
Becky
1964 Bambi II
1988 Avion 32S
09-23-2014, 04:31 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
I got my axles from Colin Hyde and had good results. That said, I did have new holes to drill and a notch to make deeper to get the new axles to mount up. Colin told me I would need these modifications. I did not have to weld on shock mounts.
New axles on old trailers can sometimes be challenging.
David
09-23-2014, 04:38 PM
Biloxi
, Mississippi
Ditto on Colin Hyde, he spected my Bambi II axle. Perfect fit and no surprises.
MICHAEL
09-24-2014, 10:04 AM
1964 17' Bambi II
Galveston
Thank you all for your help. I did order an axle from Andy at Inland RV in July and tried to have it installed in Houston. The guy that tried it install it said that it was all wrong! I don't know who to believe however I'm thinking I need another installer. This is what I ordered: HF=74.50, OB=57.88, 12" drums with 6 lug on 5.5, 3500# capacity. Tires are st225 75r 15 low range "D" . Starting angle 32 down.
Cinderella2
09-24-2014, 11:45 AM
King of the Zebra Speedo
Obrien
I ordered my new axles from Andy, and minor modifications were necessary to mount them. I documented the process, pictures and all starting in post number 169 in my "Resurrecting Big Bertha, or How I Spent $30,000 on a $2,000 trailer" thread. Call Andy up and explain your problem. Inland RV was EXTREMELY helpful in getting me the right axles and installation advice...
-Red
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
09-24-2014, 11:49 AM
Biloxi
, Mississippi
Cinderella2
Did you contact Inland with your fitment problem? They might of sent you the incorrect axle. They should make it right for you. If not you do have other options
MICHAEL
09-24-2014, 11:52 AM
Obrien
^^^^^^What AWCHIEF said^^^^^^ Dexter shipped me the wrong axles when I ordered them... Sent me somebody else's axles by mistake. Andy caught the error, before I got them installed thankfully, called me up to let me know, and then arranged to have the proper axles shipped to me express so I could make my anniversary trip that I had planned. Again, call him. They're great people.
-Red
