Old 05-21-2007, 08:24 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by 85MH325
Jack,
The design life of a rubber torsion axle is about 20 years. That said, many make it to 30, but few make it past that. The axle arm should be horizontal with the trailer frame or even have a slight down angle if it's still good. If it's pointing up toward the floor, the odds are it's bad.
Roger
My 73 has frame damage. The axle mounting plates are also bowed. Inland Andy and others more expert than I are adamant that blown out axles were a major factor in causing this problem.
Very rough finish lenny Cleaning, Stripping & Polishing 9 11-11-2002 05:42 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
Bent Door Repair Road Ruler Doors & Locks 6 09-02-2002 07:27 PM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 05:49 AM
Off The Road ALANSD On The Road... 5 07-22-2002 05:35 PM
