Old 05-09-2008, 06:56 PM   #1
crestone , Colorado
Axles on a mid '70s 26' Argosy
I'm about to purchase a mid 70s Argosey. It is quite clean inside and out. There are dates chalked on the axles, 11/99 and only light surface rust. There seems to be plenty of angle on the tortion arms. Can I assume they are good since they are less than 10 yrs old?
hopakco is offline   Reply With Quote
Old 05-09-2008, 06:59 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums. Without going into all the legalese, and "if this is that, and these are those" statements, you can reasonably expect 9 year old axles to be roadworthy.
Old 05-09-2008, 08:36 PM   #3
1973 25' Tradewind
Romulus , New York
Go for it.
jayray5 is offline   Reply With Quote
Old 05-09-2008, 08:37 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Unless the trailer has been sitting in one place since 1999, they should be fine. In the mid 70's (74 or 75) the rubber was improved in the axles.
Richard
Old 05-09-2008, 08:50 PM   #5
Well Preserved
1993 21' Sovereign
'74 was supposed to be the first year for the "new improved" rubber. They'll still go bad, just not as fast.
Old 05-09-2008, 09:07 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
Thanks for the reminder...
Richard
Old 05-09-2008, 10:38 PM   #7
crestone , Colorado
It did look like one axle tube might be bent slightly in the middle (maybe hit a rock?). I will look more closely tomorrow.
Old 05-09-2008, 10:55 PM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
The tubes are supposed to be bent in the middle. It's an alignment thing.
Richard
Old 05-10-2008, 04:03 AM   #9
crestone , Colorado
Good news- whod'a guessed.
Old 05-11-2008, 06:38 PM   #10
crestone , Colorado
So the axles are less than 10ys old but my guess is that the trailer has been sitting most of that time. How would this effect the rubber and what are my chances of making a 1300 mile trip without mishap? ( Planning on new tires).
Old 05-11-2008, 07:27 PM   #11
Rubber, must be exercised to stay flexible.
If it is not used for years, be it in a torsion axle, or a floor mat, the rubber will solidify.
Once the rubber becomes hard, it no longer performs as it was designed to do.
When the rubber solidifies in a torsion axle, it's similiar to putting solid fork lift tires on the trailer.
At this point, some axles are being replaced because of lack of use, in the 2000 and up trailers.
Jack up one side of the trailer and see how much the tire drops.
They should drop 3 to 3 1/2 inches, if the rubber is good.
Old 05-11-2008, 10:02 PM   #12
crestone , Colorado
Andy, thanks; Somewhere else I think you said there was a right and wrong way to jack up the trailer and not to use the axle?
The trailer has been moved a couple of times but has mostly sat for 7 years.
Old 05-12-2008, 12:01 AM   #13
1973 31' Excella 500
Marysville , Washington
If you have two axles you can run one tire onto a couple of 2x6's. This will provide the 3-inch difference you'll need for the 3" drop test. No jack required.
Not Done is offline   Reply With Quote
Old 05-12-2008, 12:45 AM   #14
crestone , Colorado
need to jack it.
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
