Old 03-07-2008, 04:25 PM   #1
IdahoMatt's Avatar
1952 15' Cruisette
Boise , Idaho
Any thoughts on how the axles on my '52 Cruisette are doing? I should have them looked at regardless though. Here is a link to a picture Picasa Web Albums - Matt - 1952 Airstrea...
Thanks for the help!
IdahoMatt is offline   Reply With Quote
Old 03-07-2008, 04:41 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Matt,
I purchased new axles, springs and hardware for my 1954 Liner. Not expensive about $500 for both axles, four springs and hardware. If not you need to examine the shackles and possibly rebuild. Also you will find that the current brakes will not fit in the old drums.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 03-07-2008, 04:42 PM   #3
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Matt,
You have an axle with leaf springs and not one of the torsion axles the undoubtedly you've read about here on the forums. As long as the leaves are not broken and still have an upward arch they should be fine. You may need to replace the bushings in the shackles, but other than that, I bet they are OK... so just relax and worry about other things.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 03-07-2008, 05:21 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I agree with the above posts about your axle, check the springs for cracks, check themounting hardware and mounts, and maybe change out the pads. I just wanted to add that the trailer is a really nice find.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 03-07-2008, 05:41 PM   #5
Images: 59
I replaced the axle on my '59 with a new Dexter axle, and added on leaf to the spring pack for more capacity.
It's not a hard project. Any trailer shop should be able to do it, but don't let them use the cheap (too short, too narrow) springs sold at the local Farm&Fleet. If you replace, use the same length and width springs. You can do it yourself if you have the tools and muscles.
While your at it, I would get rid of the hitch extension. It looks pretty shaky, and it will make your trailer more susceptible to sway. I'd also invest in a WD hitch.
Old 03-07-2008, 05:47 PM   #6
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
Yes, you should not loose much sleep over these axels. THe simplicity of it all! I know, the torsion suspension is smooth, but looking at the cost of replacement on my 73 I wish I had spring axels. You've got a great project there!
rob n terry
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 03-07-2008, 06:09 PM   #7
1952 15' Cruisette
2005 25' International CCD
Columbus , Ohio
Hi Matt,
Its great to see another Cruisette owner on the board. I own Ser. 8050, which is not quite as far along as yours. I've got the original axle. New leaf springs were fabricated in the mid-70's. They rode a bit low so we have extended rear shackles with grease fittings to bring it up to the desired ride height. Great looking trailer.
Regards,
Tim
Cruisette52 is offline   Reply With Quote
Reversed Axles on an Airstream HHP Axles 3 08-14-2006 05:17 PM
'78 Airstream Axles Harry W Axles 0 06-07-2006 12:09 PM
Axis Products no longer building Airstream axles. Axis Axles 11 05-22-2006 08:56 AM
New Axles for '62 Airstream Lookinghard Axles 6 10-15-2005 10:32 PM
