Old 04-08-2011, 11:29 AM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Angry Axles of Evil
If one of the guys on this site says you the axles is a 4 hour job, don't believe it. Maybe if you've done it before, and you have lifted the AS 4 feet off the ground so you can use a 4 foot breaker bar. Or you have a plasma cutting torch and 3 bodybuilder friends.
I am so mad at these stupid axles. To think that being able to remove an axle from a 64 airstream ranks right up there with graduating college or remodeling a whole house....
Couple weeks of soaking with PB, blowtorch and water, air wrench, breaker bar, and finally resorting to cutting off the bolts after breaking 2 cheaper grind wheels, having to go back for a 1/4" dewalt pro-version grinding wheel.
When I finally get the bolts out, it didn't drop. Couple more swings with a sledge hammer and it drops, but then as I try to twist it to get the shocks in a horizontal position to slide out from under the AS, it gets caught on the belly pan, and then as I try to get it back down, it catches some how and POKES A HOLE IN MY BELLYPAN! I couldn't believe it. Then, as I get it out of the hole, the mounting plate swings back one more time and catches my copper gas line.
It's EVIL. Death to the old axle. It broke rivets on the inside skin of my trailer. Good riddance.
robwok is offline   Reply With Quote
Old 04-08-2011, 12:10 PM   #2
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
You need a friend called Larry......
Luckily, mine dropped out fairly easily. But, I can imagine that things can get rusted, torqued, and twisted.
Enjoy your sense of accomplishment! You fought the fight and won!
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 04-08-2011, 12:17 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Sorry, sounds frustrating.
Years ago I spent the money to add a cutting torch to my shop. It has made a huge difference in these sorts of jobs. Much safer and easier than the grinder.
Old 04-08-2011, 01:43 PM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
A cutting torch is almost a necessity for this kind of stuff. Just cut the old bolts, or at least heat the nuts so they will come off. The same applies to 30 year old brake backing plates.. If I hadn't owned a torch I would still be out there trying to change those brakes, and I started that job 2 years ago.
While I never tried, I would think it would be possible to rent a torch somewhere.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-08-2011, 01:52 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
It's not just you. I paid a shop to do my axle swap, and it took them so long they didn't feel they could charge me for as long as it took them! So I think I got the better end of that deal!
Stephanie
Old 04-08-2011, 02:18 PM   #6
Baltimore , Maryland
One hour per axle in and out. The wiring takes me the longest. Sorry Rob.
Old 04-08-2011, 02:36 PM   #7
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Shut up Frank.
(just kidding)
Old 04-08-2011, 03:06 PM   #8
funkill's Avatar
reno , NV
Images: 27
Oh nooooooooooo --- someone that has as many mishaps in a single project as I. Thank you! People think I make this kinda stuff up.
Hope installation of the new axle went in much more smoothly & quickly.
Laura
funkill is offline   Reply With Quote
Old 04-08-2011, 03:22 PM   #9
I bet he was cursing the bolt hole alignment. Or I should say, misalignment.
Old 04-08-2011, 03:50 PM   #10
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Murphy is alive and well - I think he actually lives in my Trailer.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 04-08-2011, 04:40 PM   #11
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I was actually prepared for that part. Its the bolts that seem to have been secretly welded onto the nuts, and then covered with a layer of rust to hide the evidence that elicit the curses.
Maybe you can talk about it on the VAP and see if Colin matches your 1 hour off and on time.
Old 04-08-2011, 04:41 PM   #12
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Frank....didn't you just post about axle swaps and how much fun they are on your blog? If you ask me, you're all gluttons for punishment, but at least someone enjoys it.
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 04-08-2011, 05:29 PM   #13
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Rob
Sorry ya had so many problems. IF ya had brought it to ME and my neighbor would have changed em in about 3 hrs,depending on the beverage breaks. NO BEER neither of us Drink. I pulled mine up on about 6 inches of lumber on the front axle first. It takes a good air compressor and a really good impact. We had to presuade my axles to fall out also and we did have to encourage the new ones to slide into place(plastic dead blow hammer) Total time with beverage breaks and a rain delay about 3 hrs, give or take a few minutes.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-08-2011, 05:44 PM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It takes me a couple hours per, if I have to drill new holes. I haven't met an axle mounting bolt yet that I couldn't take off or break off with my mondo air gun... About 5 seconds or so each... I usually can cut new bolt holes with the torch faster than I can drill them. And yes, they are round.
bolts, rust, axle
I suspect it needs axles DKB_SATX Axles 22 04-26-2011 09:39 PM
