Old 04-30-2008, 08:28 AM   #1
MyFirstStreamer
Zstream's Avatar
Indiana , Indiana
Question Axles installed in 1963 on Overlander?
Does anyone know what axle was installed at the factory in 1963 on Overlanders? The wheel is a 6 lug. I would like to find as much info as possible on the factory installed axle, wheels, breaks & shocks. Thank you for your help! Z.
Zstream is offline   Reply With Quote
Old 04-30-2008, 08:51 AM   #2
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Andy at Inland RV would be the best source for you to go to for your particular question. Airstream Innovations at Inland RV Center, Inc. (951) 734-8130 He knows his stuff when it comes to axles!!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-30-2008, 09:16 AM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
The original axles were made by Henschen. The weight rating was 2600lbs.
The axles were bolted in 1963, not welded, so a replacement is relatively easy.
My Overlander had one axle with electric brakes, and one axle with hydraulic brakes. The hydraulic brakes had a device on the tongue that could lock the wheels for parking, and that could also be hooked into the tow vehicle's hydraulic system.
I removed it and installed Dexter axles with disc brakes.
The original wheels were split rims, with a 1.5in outset.
The original brake drum size was 12in x2in.
The shocks are standard issue Airstream shocks, and I would recommend that if you are running shocks that you get Airstream shocks again. Automotive Gas shocks are too harsh for this suspension system.
I hope this answers your questions.
Uwe
www.area63productions.com
Old 04-30-2008, 09:30 AM   #4
MyFirstStreamer
Zstream's Avatar
Indiana , Indiana
Thank you UWE!
A New Challenge-1963 Overlander rehab project overlander63 1960 - 1964 Overlander 896 04-07-2017 04:48 PM
Dexter Axles INSTALLED... TN-TUNDRA Axles 17 03-29-2008 09:09 PM
1963 Overlander Electrical Adaptor / Brakes erikjware Brakes & Brake Controllers 1 02-22-2008 03:43 PM
New Axles Installed Buttercup Axles 7 07-25-2005 05:39 PM
new axles installed for $1400.00 cnd. '75 argosy mtour Axles 3 08-11-2004 05:09 PM
