Old 12-29-2011, 09:51 PM   #1
1976 Argosy 24
alpine , Wyoming
Axles in the Sacramento, CA. area?
hi, i am in the sacramento , ca. area, looking for shop to replace axels on 76 argosy 24ft. thanks don
dcribbins is offline   Reply With Quote
Old 12-30-2011, 02:18 PM   #2
Yomster's Avatar
1968 26' Overlander
London (UK) / San Francisco , London / California
Images: 13
Hi Don, I was just about to post the same request. My initial search indicated that Toscano in Los Banos may be the closest, but I stand corrected if someone else has a better suggestion. I'm getting my axles from Inland and will have them fitted closer to home.
I'll post more details if I find some.
Y
Yomster is offline   Reply With Quote
Old 12-30-2011, 05:43 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Toscano's is a great place. Not that difficult a drive from Sacramento. If the job takes more than 1 day (shouldn't) they probably will let you stay in your trailer overnight....full hookups......free.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 12-30-2011, 05:56 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Not the most difficult job to do yourself. Consider having them delivered and do the install yourself. You can save more than half if you're able to do it at home. Inland RV is in the LA area and has axles that fit your model. Give him a call.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-30-2011, 07:26 PM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
I will concur that an axle swap is not a difficult DIY job; you'll need jackstands, a jack, sockets set & wrenches, penetrating oil and basic wiring tools to disconnect and reconnect brake wires. A buddy is a good idea too, of course, so that'll set you back some post-job brews .
Well worth buying the tools if you don't have 'em already..
Being able to do basic mechanic's work like this means that you'll have a lot easier time out on the road if something should go wrong.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
I suspect it needs axles DKB_SATX Axles 22 04-26-2011 09:39 PM
