Old 05-18-2012, 07:57 PM   #1
1977 31' Excella 500
Red Rock , Texas
Axles in the AM...
Wish me luck!
It was really easy to order them at Inland...
I hope the installation goes as simple!
junkyardawg is offline   Reply With Quote
Old 05-18-2012, 08:29 PM   #2
GlobeTrottin's Avatar
1964 19' Globetrotter
Chelsea , Michigan
Been there... I remember more broken drill bits than we planned on... biggest surprise when I did mine four years ago in my 64 was when I pulled the old one off, it was dated manufactured in 1973. No explanation for that one...
Good luck and don't forget to take a break now and then!
GlobeTrottin is offline   Reply With Quote
Old 05-18-2012, 09:04 PM   #3
Max Well's Avatar
1971 25' Caravanner
Olathe , Kansas
Junkyardawg,
You can do it! I did mine and just needed help to horse the new axles under the trailer. With the Inland axles I don't think you even need to drill. I bought from Colin Hyde, so I did drill, but it was no big deal.
You won't believe the difference in the ride quality! No more damage!
Good luck!
Ken
"Surrender is not in our creed. Let me hear you say that..." Gunny Hiway
Max Well is offline   Reply With Quote
Old 05-18-2012, 10:00 PM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
You can do it without any problem. If it helps, check my thread for pics when I did mine. Just search for threads started by "Aviator"
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 05-19-2012, 07:48 AM   #5
Red Rock , Texas
Looks straight forward enough. not sure exactly how this shock goes together, but I'm sure it will be apparent once I get it lifted and the wheels off. A buddy is coming out with tools and skill, and my wife bought us a lot of good beers and two big racks of ribs for the smoker...
Gonna be a good day...
Old 05-19-2012, 08:29 AM   #6
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
That actually sounds like fun! I did the swap by myself. Having a buddy around would have made it much easier.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 05-19-2012, 09:11 AM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
For me the hardest part was getting the old axles out from under the trailer, using a small, or a small and large scrap of plywood stacked together to make a slider bearing or dropping the drum onto a caster wheeled dolly would eliminate most of the grunt work. My driveway is ancient asphalt and I ended up borrowing my neighbors lawn tractor to snatch them out, and used the sheet plywood trick getting the new ones under & positioned
Old 05-19-2012, 10:18 AM   #8
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
Junkyardawg,
How long did it take for you to get your axles from Inland? We ordered our May 3 or 4 and they have not been shipped yet.. Andy said they were in stock and should go out by that monday. Nothing shipped yet
Plus our credit card has been charged.. Nothing like paying for something that hasn't even been shipped.
Good luck with your axles...
Jane
Janie Q is offline   Reply With Quote
Old 05-19-2012, 01:49 PM   #9
Originally Posted by Janie Q View Post
Junkyardawg,
Jane
That delay was caused by a huge shock bracket back order, which has now been resolved.
Old 05-20-2012, 06:57 AM   #10
Red Rock , Texas
Well, it was a good day. The weather was perfect. The beer was good and cold. The ribs... They were amazing. They smoked until they were just so close to falling apart... Awesome.
The trailer was lifted, axles prepped and installed with no problems at all. It was actually a kind of fun job... I got mine from inland about two weeks after ordering.
Old 05-20-2012, 07:47 AM   #11
Max Well's Avatar
1971 25' Caravanner
Olathe , Kansas
Congrats. I knew you could do it! It's even better with friends. Did you take before and after pics?
