Old 09-20-2014, 08:08 AM   #1
harryk's Avatar
1993 25' Excella
Venice , Florida
Axles....great fit !
Thanks to Colin Hyde, I am starting out with new axles, drums, brakes, bearings, etc.
The axles fit like a glove ! Thank you Colin !
Project was on one hand fairly easy in that there were only 8 bolts involved but also difficult because the old bolts had to be cut off. (I have a torch)Installing the new ones was fairly easy, once they were dragged under the trailer thru Florida sand & shell. It was a matter of jacking into place & installing the bolts. One other minor problem was the supplied lock nuts were impossible to install by me ...couldn't get enough leverage while lying on the ground. Changed them to standard nuts with a standard lock washer and then had a neighbor weld the nut to the bolt. Also, its important to face the bolts that go behind the shocks IN so there is clearance for the shocks. (Found this out the hard way.) I do not think this job is for everyone, as it required some brute strength (friends) and some heavy duty tools. I am pleased with the final outcome !
harryk is offline   Reply With Quote
Old 09-20-2014, 01:17 PM   #2
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Glad you are all together. Must be riding high Huh??
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 09-20-2014, 01:37 PM   #3
The square holes have NOTHING to with alignment.
They simply provide a place for the square shaft.
Old 09-20-2014, 03:50 PM   #4
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
You make it sound harder than it should be - I'm 72 years old and did it by myself using two small furniture dollys and two small floor jacks from harbor freight. I used Blaster two days before on the nuts and they came right off. It took three hours for the first one and two for the second one - (you have to put the shock on the axle before you put it up in place - learning curve).
Silver Hawk is offline   Reply With Quote
Old 09-21-2014, 07:15 AM   #5
harryk's Avatar
1993 25' Excella
Venice , Florida
The hard part was dragging the axles thru sand & shell...as they were dragged, they dug in deeper etc. (could not use a dolly because it too dug in.
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
Shocks don't fit with new axles blickcd Axles 3 04-21-2009 06:59 PM
Will 2004 Henschen Axles fit under 1971?? Pschoerrn Axles 15 09-05-2006 06:18 AM
My new axles don't fit DavidsonOverlander Axles 5 11-21-2005 01:13 PM
