11-12-2008, 06:57 PM
1974 Argosy 28
Fresno/Clovis
Axles-Good-Bad-Just Passing??
I tested my axles by jacking up each wheel under the brake drum, when I was doing the brakes. I found each wheel would flex 2-3-inches before raising the trailer off the ground. When the trailer is on blocks the angle if the axle is level. I think the 2-3" movement tells me the axles are not "toast" yet. Anyone??
Roger
11-12-2008, 07:10 PM
Corona
Roger.
Two things.
The jack up test demonstrates that the rubber rods have not solidified.
The position of the torsion arms on your trailer, demonstrate that the rubber rods have lost some of their ability to hold up the weight.
In your case, when the trailer is loaded, the torsion arms should not be more than parallel to the chassis. If they are going upward, as they go rearward, then their time is almost up.
You can also further check out your axles any time you wish, by simply looking at the position of the torsion arms.
11-12-2008, 07:58 PM
1974 Argosy 28
Fresno/Clovis
Andy, when the axles are loaded, they are level. My concern is, when they are unloaded, they are still level. So, I think they have some life left, just a question of how much.
Roger
11-12-2008, 08:07 PM
Central
, Mississippi
In the simplest terms, a suspension is supposed to do 2 things.
1) support the trailer so it doesn't drag on the ground
and
2) move when you hit a bump
so,
if the thing isn't bottoming out
and
when one axle is run up a ramp for +2 inches and the other is still on the ground, it must be moving
you are ok.
11-12-2008, 10:34 PM
Corona
Roger.
Your correct. How much life is left, is the question.
All you can do is check the position of the torsion arm, before and after each trip. When the torsion arm starts going up hill, the partys over.
That could take a few weeks to a few years. You have to be the judge.
The only other thing to watch for is furniture damage, or rivet heads that start to disappear. Then you know it's time when that happens.
Have a safe trip with your family.
Andy.
11-13-2008, 01:01 AM
1974 Argosy 28
Fresno/Clovis
Thank you for the info. We travel light, and travel for short periods of time, long weekend, or 4-5 days at a time. when not using the trailer, I plan on keeping it on jackstands, as has been recommended elsewhere on this forum. I keep the tires lightly on plastic style blocks, ones with holes so the tires stay dry and cover them up. I will continue to monitor angle when loaded.
Thanks again,
Roger
11-13-2008, 01:18 PM
1999 27' Safari
Kent
, Ohio
I do know that any Airstream dealer can check your unit. Also Becareful jacking up you axle by the drum. They are not designed to do that. You risk cracking them or bending them and probably wont realize that till you apply your brakes on the road.
11-13-2008, 02:23 PM
2004 30' Classic Slideout
Fenton
, Missouri
OK folks. Several of the moderators have taken action on posts in this thread which for all intents have attempted to hijack the thread from the original poster's intent and drudge up issues on another thread that went south.
The moderation staff tires of constantly having to deal with issues resulting from axle discussions which get pulled into personal issues. Side comments or other pointed remarks which are added into to posts or are posts themselves that intend to potentially provoke or inflame others will result in your future posts being moderated. We don't want to do this but we are being left with no choice.
I have reopened this thread for those posters who wish to provide productive content.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
11-13-2008, 05:50 PM
Belington
, West Virginia
11-13-2008, 06:12 PM
1977 27' Overlander
Trotwood
, Ohio
Roger Dodger
Like Charlie Brown above me . He is thinking of saving his pennies, and so should U. When the time comes U will be ready.
Roger
Over
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
11-13-2008, 06:38 PM
1976 31' Sovereign
Chandler
, Oklahoma
I'd like someone to post of picture of what I should be looking for and what I don't want to see. I'd also like a good picture of a trailer "jacked up" properly. I hear a lot about torsion arms and angles, but frankly it's all just words to me. Now I'm sure somewhere on this Forum there are pictures, and I've checked out Andy's site; however, I would just like to see a classic trailer with "yes" and "no" on the axel pictures, and "jack it up here" on the other pictures. My 78 and 76 ride very high up on the wheels and I can pull them with a coke can on the counter that will never move, but both are old and only pulled a few times a year.
Judy At Home in Oklahoma
11-13-2008, 06:49 PM
1964 26' Overlander
1964 19' Globetrotter
OlyPen
I would like to suggest that it is hard to diagnose from photos - angles can be deceiving.
11-13-2008, 07:08 PM
Corona
The Airstream looks ok, but the proof is in the position of the torsion arms.
The second test is to jack up one side of the trailer at a time. The tires should drop about 2 to 3 inches. If so, the rubber rods are not solidified, and have life left. If the tires do not drop but a small amount, then the rubber rods have solidified, making the axle bad.
According to Henschen, when the trailer is loaded for travel, if the torsion arm, as it goes rearward, are uphill, the axles are done.
If the torsion arms are parallel to the chassis, the axles are on their last legs.
The following article will help you.
Dura Torque Axle
11-13-2008, 07:17 PM
1974 Argosy 28
Fresno/Clovis
Originally Posted by Mikethefixit
Roger Dodger
Roger
Over
From one Roger to another, I hear ya loud and clear.
Roger, over and out.
Roger
01-01-2009, 10:30 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
You can tell that our 63' Safari needed axle replacement by how much of the tire sidewall is visible, none. [Sorry this was the best photo I could find]
The other photo shows where I place the jack stands for winter storage, I use the vertical axle plates as jack points.
Hope this helps.
