Old 02-23-2014, 09:38 AM   #1
1972 25' Tradewind
Midwest , Indiana
Axles Degree - 1972 Tradewind
I'm going to be ordering new axles for my 1972 Tradewind. When the axles were new, does anyone know the down degree that was used? Thanks.
reddog60 is offline   Reply With Quote
Old 02-23-2014, 10:23 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The default down angle is 22.5 degrees.
If you're ordering directly from a non-Airstream-specific source like Redneck Trailer Supply, be sure to get the right measurements and bracket configuration.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 02-27-2014, 06:17 PM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Your trailer originally had 22 1/2 degree down angle, however you can opt for 32 degree if you want greater ground clearance. Virtually all of the axles we've supplied for 70's era Arirstream's have been built with Henschen type mounting brackets & shock brackets welded in place, so no drilling or welding is required.
Good luck,
Colin
Colin H is offline   Reply With Quote
1972 Airstream Tradewind Land Yacht reddog60 Airstream Registry Discussions 0 08-19-2011 08:32 AM
1972 Tradewind interior ehodg66 General Interior Topics 6 06-01-2011 10:00 PM
