07-20-2015, 09:56 AM
#21
Superannuated Member
2001 19' Bambi
Beaver Lake
, Arkansas
I agree with drboyd, replace them as a pair.
07-20-2015, 07:08 PM
#22
Mission
Are the shock mounts on replacement axles configured the same as the original axles so that the chassis mount side can be the same?
Or are we stuck with (having someone else if you don't weld) welding new shock mounts to the chassis?
Also new bolt holes?
How much (if any) of this changes when opting for the 3" raise?
07-21-2015, 12:02 PM
#23
1975 31' Sovereign
Lebanon
, Pennsylvania
I called Colin and sent him an email 2-weeks ago. No response. His email inbox says its full. Please help. I need new axles.
07-21-2015, 12:57 PM
#24
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Hang in there and give it couple of tries. He is very busy and goes to rally's. He may get inundated with forum members needing advice. I think email worked best for our contact with him.
Hittenstiehl
07-21-2015, 06:14 PM
#25
Mission
Again I ask ...
07-21-2015, 06:58 PM
#26
Biloxi
, Mississippi
Axles spected by Colin Hyde come with the shock mounts correctly attached.
MICHAEL
07-21-2015, 07:32 PM
#27
Mission
AWCHIEF thanks a million!
Welding isn't my favorite.
07-25-2015, 10:01 AM
#28
Corona
Originally Posted by jimmbob
We purchased a '76 31' LY last fall. Took her "Lucille" on her maiden voyage two weekend's ago. Love this forum. Would it be bad to buy 1 axle and when the AS fund built up buy the other axle? Jim Tecch Lucille
Jim.
When replacing older axles, replace them all at the same time.
If you install a new axle along side of an old axle, you will "RUIN" the new axle, since it will carry more weight because it's starting angle places the torsion arm further down ward. It also will set up a sway because it will carry more weight than it's supposed to.
Suggestion. Purchase one axle now, and put it in storage. When the other funds become available, then purchase the second axle. In stall both at the same time.
The only problem with that method is that you will be paying for freight, "TWICE".
Perhaps a better suggestion, is save up the money for both axles, and order them at the same time.
07-25-2015, 10:44 AM
#29
1969 29' Ambassador
brooksville
I got my axels through Andy at Inland RV the were very helpful and walked me through it. Shipping is a big cost, so don't pay for it twice. If you opt for the steeper down grade to raise the trailer, dexter will not weld the shock brackets on. If they are shipped from the dexter factory to you, expect to have to weld them on. If they ship from Andy's place they will weld them on before they go out.
Andy feel free to jump in and correct me if things have changed.
07-27-2015, 06:38 PM
#30
1972 25' Tradewind
ashland
, Missouri
The brackets were on mine, but you have to weld on stud,or I made a bolt for shocks to go on, No changes I got 3" to 4 " lift with 32 degree. Call me if you have other questions 5738818922 RED
07-29-2015, 03:35 PM
#31
Blowme
, Oklahoma
About how long from order to delivery with the welded shock mount? without?
07-29-2015, 05:22 PM
#32
Corona
To answer your question.
2 to 2 1/2 weeks without, but freight from Texas, shock brackets sent USPS.
3 days from California, with.
11-20-2015, 10:16 AM
#33
1973 23' Safari
1970 27' Overlander
Boerne
Is it best to weld the shock brackets on before installing the axles, or after the install to insure a proper fit?
11-20-2015, 12:01 PM
#34
Corona
It's best to weld the shock brackets on, before the axles are mounted.
The bracket should be at the outside edge of the torsion arm, with the shock stud facing inward.
