Old 05-13-2005, 06:14 AM   #15
Somewhere , Indiana
Originally Posted by pattersontoo
I do have some concerns about my axle replacement on the Argosy 20 though.
First of all, can an ActiBrake unit be mounted in a small space? How big is this unit? I do not have a lot of space on the front tongue of that trailer and I would like to go with the disc brakes and the ActiBrake unit. That trailer is heavier and wider than my Minuet. I am also planning on taking it into the mountains. I would feel better if it had the disc brakes on it.
Thanks.
Lou,
Here is the installation manual for the Actibrake . www.activetech1.com/actibrak/brakesystem/install-man04.pdf
When paired with the Kodiak disc brake system, I can tell you from experience, you will have a winning combination . The manual is written in a simple but detailed format. If you still have questions after reading this let me know I will be happy to gather additional information.
Regards,
Henry
axleman is offline   Reply With Quote
Old 05-13-2005, 07:04 AM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by axleman
Lou,
Regards,
Henry
Henry, since we are talking disc brakes again, why (besides cost) couldn't ABS be offered with the disc brakes? With the hydraulic system in place, all you would need would be a tone ring and pulse generator for each wheel, an accumulator, and ABS module and controller. A SWAG (scientific wild a guess) would put the additional cost at around $600-900 more, for up to two axles, using more-or-less off the shelf components.
With new Airstreams costing $90,000+, that would be a drop in the bucket, an they could then most likely be touted as the first travel trailers in the world with ABS.
Old 05-13-2005, 07:18 AM   #17
Images: 59
Along with ABS, how soon will 'Trailer Stability Assist' be available.
I have read that Continental Teves is working on a system that will detect trailer sway. The sytem would activate brakes on opposite sides to eliminate the sway. It might be available on the Toureg and Cayenne. Has anyone tried it?
No real info on when it would be available as aftermarket, or what it would cost. It would be nicer than hooking up the old dual cams.
Old 05-13-2005, 07:22 AM   #18
Somewhere , Indiana
Great Question
Terry,
GREAT QUESTION!
Let me do some research on this topic. I shoot straight, if I donít know something I fess up about it . We donít design brakes, disc or other, we install them. However, I do have some great contacts with trailer brake manufacturers and I will lean on them.
Answer to come! Please stay tuned to this network for updates as they become available .
Regards,
Henry
Old 05-13-2005, 09:04 AM   #19
C.T. is working on that right here in Auburn Hills, MI. They have a huge testing facility.
I keep forgetting that I have a trade publication that is distributed here in the Auto Capitol of the World. One copy I have has a blurb about this in it. It has a couple drawings and stuff in it too. I will dig around my office and get it scanned. It is going to revolutionize trailer towing. At least that is what they say in the article.
If there is interest in this article I will see what I can find out. I have a friend that is working on a different project at C.T. He can get more information.
Anon is offline   Reply With Quote
Old 05-13-2005, 09:06 AM   #20
ABS would rock.
Terry has it pegged for what would be needed.
Let's design and build our own!
NAH! It is more fun to camp in them than it is to work on them!
Old 05-13-2005, 05:01 PM   #21
till's Avatar
Lisle , Illinois
Images: 108
Talked to Henry today.
Looks like I will be draggin one of the old Ambassador axles out to him for a little "copy" magic.
I like this whole thing very much Karma for you, Lou when I am allowed again.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 05-13-2005, 05:44 PM   #22
Thanks for the kudos, even if you cannot give me karma!
Once he has an Ambassador axle that will make it much easier to make even more of them!
I have a lot of faith in Henry AND Axis Products. I think I have stumbled onto something good for all of us.
Old 05-13-2005, 05:57 PM   #23
Well Preserved
1993 21' Sovereign
If it can be done, it would eliminate all manner of towing-related problems. It could virtually eliminate sway, increase tire life, as the tires would not get flat spots from skidding and have to be replaced, there would be almost no more jacknifing issues, towing during slick weather would be much safer.
Old 05-13-2005, 06:04 PM   #24
Images: 59
Lou,
Really would like more info on the C.T. system in the Toureg. I assume it detects sway at the back of the tow vehicle, and applies just enough alternating brake action (on the tow vehicle, not the trailer) to counter the sway. Works in conjunction with dynamic vehicle stability system that is getting more and more popular.
What I'd really like to know about are the Electronic brake systems that use a DC positioner to actuate brake caliper. Can you find out from your friend when they will be available? I know they will need 42Vdc, so it may be a few years or more.
Thanks. Sending you some K.
Old 05-13-2005, 06:10 PM   #25
Lou,
Thanks, buddy! I will return the favor.
I did not work this week. Had some personal time I had to burn before the end of the month. I will dig around in my office tomorrow. It was back a few months ago that I came across the article.
I am going to be seeing my buddy sometime next week. I have an appointment next week at C.T. and I will being doing lunch with him. I will hit him up then. Be sure to remind me as I will forget.
Old 05-13-2005, 06:15 PM   #26
Images: 59
Lou,
Here is the web site: http://www.conti-online.com/generato...2_0602_en.html
The first item (EHB) is similar to the Actibrake device. What i'm interested in is the time horizon for the Electro Mechanical brake (EMB), the second item.
Thanks again.
Old 05-13-2005, 06:21 PM   #27
I will check into it next week, partner.
It is a cool idea, you know?
Old 05-13-2005, 06:35 PM   #28
Images: 59
Imagine what you could do if the trailer brakes were fully integrated with the tow vehicle, and a yaw rate and lateral g' sensor? All you would need to do is flip a switch on the dashboard!
