Old 11-09-2007, 02:05 PM   #1
West Islip , New York
axles
Again the manual states the you have to be real careful when traveling as the axles come out of alinement. Has anyone really had this problem. I will be traveling from NY (long island) to Fla. The roads out of NY are not the best so it will be almost impossible not to hit some bumps. I can not image that I will have to aline the axles after every trip. I hope it is just the writers of the manual covering all there bases. Rob
katsix is offline   Reply With Quote
Old 11-09-2007, 02:19 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
First off, welcome to the forums!
There is lots of information here about axles...so much so, we have an entire sub-forum dedicated to the subject (I've moved this thread there). You may want to get up to speed on some of what has already been posted. Axle threads often get tumultuous...but the bottomline is, yes, your wheels and axles can get out of alignment. However, it's not by just traveling down the road over everyday bumps & cracks in the road. It is however advisable to have you alignment checked periodically (not after every trip!). Axles and wheels that become unaligned can cause significant damage.
You don't mention what trailer model/year you have...not that it matters, except if it is vintage you may have leaf springs instead of a torsion axle.
Shari
Old 11-09-2007, 02:51 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
It is highly unlikely you will disturb the axle alinement traveling to Fl. Once you clear NY city the roads are fine.
If your axles are out of alinement you will see abnormal wear on one or more of the tires. I say or more because a missalined axle will cause wear on itself and often on another tire on the other side. If you have good rubber on the trailer now measure the tread depth across each tire before you head south and check it in Fl. and again when you get home. If the measurement change other than equealy across any of the tires you may hae and alinement issue
If you do infact see abnormal wear do not consider Jackson or a dealer as a means to correct the problem. Gommer's in Chambersburg Pa. is who the factory recomended after they failed to aline mine.
2004 Excursion 4x4
Old 11-09-2007, 04:49 PM   #4
1972 25' Tradewind
Madison , Wisconsin
Alignment
When I installed my replacement axels, I aligned them by measuring from the front of the A frame to the same point on each axel. I was told that anything less than 1/8th of an inch was good (25 ft. trailer). I'll check it again this next summer after each of the first couple 0f trips.
Alignment is something you may be able to do yourself.
Smokin Camel is offline   Reply With Quote
Old 11-09-2007, 05:31 PM   #5
HowieE's Avatar
Images: 12
Airstream does not use a beam axle but rather a torsion type. Yes you may be able to get a beam axle close by just measureing from a common point. The torsion axle has 2 additional parts that figure into it. The arm and the spindle are the point most likely to be out of alinement and thus just setting the beam may not complete the job.
I toured the axle factory when I picked up my new axles. Even after reasonable consideration while installing them I still took them out to Gommer's for alinement.
2004 Excursion 4x4
Old 11-09-2007, 05:33 PM   #6
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
If you are seeing unuasual wear . CHECK THOSE TIRE PRESSURES FIRST!
Mikethefixit is offline   Reply With Quote
Old 11-09-2007, 05:46 PM   #7
HowieE's Avatar
Images: 12
By unusual wear I ment uneven side to side of a tire. Low tire pressure will give even wear side to side.
Missalinement will most often cause a tire to show wear on one side because it is either toed in or out or because the camber angle is off. Since we are dealing with a trailer there in no caster angle consideration.
2004 Excursion 4x4
Old 11-09-2007, 05:48 PM   #8
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Often unusual wear can also be caused by imbalance of the hubs/wheels/tires.
Uwe
www.area63productions.com
Old 11-09-2007, 07:52 PM   #9
I was just seeking information. I do not pick up my new 23' safari till Dec. It is being built now. I had the dealer send me a owners manual and after reading it ...... I have more questions then before. I had a single axle Casita and never had a problem. The double axle seems to have some possible problems. I quess that I will just make sure I have it serviced by an airstream dealer. Thanks for all the information. Rob
Old 11-09-2007, 08:02 PM   #10
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
If you use your trailer in the way that it was intended to be used, you will very likely not have any problems with your axles or their alignment for 20 or so years, maybe longer. This is not considering hubs, bearings and brakes. Thoise need servicing ona regular basis.
You can relax, and revel in the anticipation of a new trailer in just a few more weeks! Axles Shmaxels....
Uwe
Old 11-09-2007, 10:23 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Torsion Axle alignment
The original torsion axle on our '65 Caravel broke so I had to replace it. I asked the Authorized Airstream repair guy if he had aligned the new axle, he said that he had. I drove from California to Pennsylvania and needed new tires. By the time I got back to California I needed another new set of tires. My local tire shop sent me to Stockton, California to an aleignment shop that does it the old fashion way. That was over 50,000 miles ago. I have replaced tires, but not due to alignment. They wear evenly.
A torsion axle should be aligned when installed new. It is done by bending the main square tube which runs from side to side, using a port-o-power and chain. First on one side, then the other. The tongue should be at tow hight. If the axle tube is perfectly straight and does not have the paint scratched on it from the chains, it most likely has never been properly aligned.
Old 11-10-2007, 12:07 PM   #12
Can't speak for other torsion axle manufacturers, except Henschen.
All Henschen torsion axles are aligned to specs, as part of the manufacturing process. That has been their procedure since the early 1960's.
Old 11-12-2007, 12:21 PM   #13
What brand axle was installed?
It would also be helpful to others to know what dealer did the axle changeout.
Old 11-22-2007, 10:03 AM   #14
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
Henshen Alignment
I installed Henschen axles on my '78 Sovreign and have recently noticed uneven side to side tire wear. The spacing between the axles at the wheel rim is 7/16" wider on the left side than it is on the right. The axles may have been aligned when manufactured, but apparently the holes in the trailer frame were not. There was no significant bolt hole clearance in the frame, so the axles are where they always were.
Oasis in Tucson said "That sometimes happens". So alignment is required , and soon!
Harry W
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Axles nairnchyz Axles 3 04-02-2007 02:13 PM
New Axles garthbf Axles 4 08-07-2006 07:27 PM
Got Axles??? Action Axles 25 04-16-2006 08:09 AM
Need New Axles Navigator Axles 138 12-19-2004 10:00 AM
two vs three axles? newmanjk Axles 17 08-05-2004 04:03 PM
