06-16-2004, 01:26 PM
axles?
please humor a blonde but how can you tell if an axel is bad on an argosy?
I wish I had an airstream!
Just one airstream!
airstreamDreamer2
06-16-2004, 01:44 PM
1984 29' Sovereign
Savannah
, Missouri
There's several way`
Not to worry..I've been practicing all my life, humoring blondes..lol
There's several excellent ways to get an 'idea' about the condition of axle.(not axel)...
First, go to this website...read~InlandRV
Click on the section about axle..
Here's another site~Dexter
Secondly, there's a "general rule" that, if the top of the wheel is below the body of the wheel housing area..Then, it may well need to be replaced.
Of course, age has a factor as well..I don't think the argosy were being built prior to 64, so that in itself shouldn't be a factor.
Outside of those simple things, you then get into the mathematical aspects.
All of which can be further researched on here by looking under axle, replacement of axle, general comments along that line,etc.
You can also look at the pictures of my unit in the photos section for an example of what's considered to be good axles..
Here's the link to that:53FC wheels`
How we doing?
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
06-16-2004, 03:54 PM
1964 26' Overlander
1964 19' Globetrotter
OlyPen
In general - it's probably resonable to assume that any argosy or airstream you find from the seventies will need an axle replacement , if it hasn't already been done. Axles seem to last about 25 years. The good news is that it's easy to do and you can do it your self with some jack stands and a floor jack (rent or borrow if needed). We love our argosy and every time we take it anywhere we are asked for tours, tales and if there are any more for sale.
06-16-2004, 04:28 PM
yeah my hubbie and I are looking for an argosy. We keep finding decent tailors, but the bank won't finance anything under 1990. So it's a saving we go.
Just one airstream!
airstreamDreamer2
06-16-2004, 05:45 PM
Retired.
, At Large
You may want to check with Rog (rog0525) on the forum. He has, or had, a nice looking Argosy he was wanting to sell. I have forgotten how much he wanted, but it was reasonable.
06-16-2004, 06:12 PM
Just a member
1978 28' Argosy 28
Lutz
Originally Posted by Janet
In general - it's probably reasonable to assume that any argosy or airstream you find from the seventies will need an axle replacement , if it hasn't already been done. Axles seem to last about 25 years. The good news is that it's easy to do and you can do it your self with some jack stands and a floor jack (rent or borrow if needed). We love our argosy and every time we take it anywhere we are asked for tours, tales and if there are any more for sale.
Note: Andy Correct me if I am wrong:
In 1974 there was a change to the rubber inserts that were used in the DuraTorque axles. If you are looking at any trailer 1974 or older it could be a candidate for an axle. The PO (prior owner) may have replaced the axle, but you need to calculate the possible costs to do an axle in your hunt. You are not assured that a post 74 trailer will not need an axle, but it is less likely based on the PO usage. Follow the advice on the inlandrv site regarding how to tell if your axle is bad.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
06-16-2004, 06:26 PM
Corona
thenewkid64
Brett.
Absolutely correct, on the 1974 on back axle issue.
However, someone said that the rubber rods are good for about 25 years. "That is not true."
If it was then there would be many 1979 and older trailers with bad axles.
What is true, is that if the trailer will be parked for a long time, most of the weight should be removed from the axles. That will allow them to return to there original starting angle, to rest.
If the weight is not removed, any year axle will settle, and therefore in time, become defective.
Most people buy an Airstream product to use it. The axles love you when you do. They (the axles) like us, must have some exercise once in a while. If we don't, we ultimately suffer because we didn't. The same basic thing happens to "any" rubber rod axle, regardless of manufacturer or the kind of equipment it may be on, from boat trailer, to farm implements, to Airstream trailers (Argosy too).
We have replaced many axles on trailers 10 to 50 years old, because they stayed parked for years on end.
As Mr. Favor use to say, "Head em up and move em out."
06-17-2004, 03:44 PM
1968 22' Safari
1976 27' Overlander
Newport
I didn't think you are a blonde?????
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
I suspect it needs axles
DKB_SATX |
Axles |
22 |
04-26-2011 09:39 PM |
