Old 12-10-2013, 12:35 PM   #1
1972 27' Overlander
Canyon , Texas
Axles???
Hello to all; My name is Jake and I'm new here.I have 1972 overlander. I have seen some threads about replacing axles and am wondering how to know when it's necessary?
We have had our AS for 14 yrs and never a problem. ....... with the axles that is! Any input would greatly appreciated!
air-jake is offline   Reply With Quote
Old 12-10-2013, 01:03 PM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Hey Jake
Welcome to the forums.
More than likely your axles are shot, the rubber rods that provide suspension and cushion your trailers ride have hardened and or are sagging so that you have little or no suspension travel. This transmits all road shock to your trailer. I know there are many threads on this subject. I'd try googling how to tell if my airstream axles are bad or something similar.
Good luck
Mike
desertair27 is offline   Reply With Quote
Old 12-10-2013, 01:27 PM   #3
You can check the axles out yourself, by reading the following.
Torsaion axles last about 25 years or so.
The Dura-Torque Axle
Old 12-10-2013, 01:31 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Here's an article from one of our commercial members about checking axle condition.
Basically there are 2 things to check, whether the axle sits with some down angle (down from the axle tube toward the hub) and whether the wheels drop when you lift the trailer. There's a graphic illustration in the article about the down angle, and the article says the wheels should drop 3" from loaded before they fully lift off the ground.
David
Old 12-11-2013, 09:15 AM   #5
1972 27' Overlander
Canyon , Texas
Thanks guy's, I've learned more about my AS on this site in two weeks than I have since I bought it 14 yrs ago!
I'm planning to convert my AS into a mobile kitchen so I will have tons of questions.
#1 Am I insane???
Old 12-11-2013, 09:18 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
ANSWER #1- YES WE ALL ARE.
Sounds like you might be adding some weight to the trailer, you might need axles to accomodtae that weight.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-11-2013, 09:44 AM   #7
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
#1 Am I insane???
We've done many axle replacement/upgrades, & based on what your plans are, you'll definitely need a much higher load rating than what is on your trailer now. Keep in mind that these frames were not designed to support all the typical equipment you would find in a mobile kitchen. You will certainly require some reinforcements in the frame structure & more than likely a new floor. You really need to work out the weight of what you are adding & where you hope to position it. Then a plan can be created for frame & axle upgrades to suit.
Colin
Colin H is offline   Reply With Quote
Old 12-11-2013, 12:43 PM   #8
#1 Am I insane???
There is a way to get started, that you can do on paper.
Don't spend any money on anything for that Airstream, until you do the following.
1. Make a detailed drawing of how your going to place each piece of equipment.
2. Estimate the weight of each piece of equipment.
3. Make sure that you keep at least 55 percent of the weight, forward of the axles.
4. Calaulate the total weight so that you can purchase the proper axle rating.
Use the equipment weight, the trailer weight and the pay load weight.
5. The big project is to open up the bottom of the rear end shell, so that you can beef up the shell to floor to chassis attachment.
(b)FAILURE TO DO SO WILL RESULT IN REAR END SEPARATION.(/b)
5. Depending on your overall weight, you might need to add the axle mounting "beef up" plates.
6. If you attempt to wild guess of how to do the huge change, you will be wasting a lot of time, and money.
We have made many conversions over the years like you plan, but I shut my service department down about 1 1/2 years ago.
Making a huge converswion, is OK, BUT, start off on the right foot, so you don't waste any of your time or money.
Andy.
Old 12-11-2013, 02:33 PM   #9
1972 27' Overlander
Canyon , Texas
I agree, as soon as I know where and what I will share the info and try to get some input.
Old 12-11-2013, 03:01 PM   #10
Riverrat6270's Avatar
1980 31' Excella II
Springfield , Illinois
A buddy and I installed a set that I purchased from the folks at Inland RV. The service and support I have received from Andy and his crew far surpassed any reason to shop anywhere else. Took about 4 hours to get organized and get the first axle installed and about 2 hours for the second. Definitely would be concerned about the weight you are adding.
Riverrat6270 is offline   Reply With Quote
Towing with Bad Axles CF Av8or Axles 15 02-11-2012 05:19 AM
Axles Parallel With Frame? rwkrapfel Axles 11 02-02-2012 07:22 AM
