Old 04-25-2007, 07:27 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Axle weight ratings
If I were to find a good used axle (contradiction in terms?) how do I determine the load capacity? Is there a stamp or plate, etc.?
I realize replacing a used bad axle with another used axle may be asking for trouble, but I know where there is a set on a trailer I can get for free and it seems it is at least worth checking out.
Will axles from newer coaches, say 2000+ fit vintage coaches, say my 73?
Lumatic is online now   Reply With Quote
Old 04-25-2007, 07:44 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
I'm not an expert but let's start. Like current Airstreams, your '73 has a torsion axle. It might be a deal killer if the 'found' axles have leaf springs. I do know that welding bolt tabs on a torsion axle ruins the rubber rods inside. I suspect you'll find you only want to do this with an Airstream-specific axle. Put on a hard hat and browse more of this axle subforum while waiting for the 'sperts to chime in. Let us know what you do!
5 meter Langford Nahanni
Old 04-25-2007, 07:57 AM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
I have pretty much dismissed out of hand putting on an axle with leaf springs. I assume they would significantly change the towing characteristics and not for the better. But has anybody done this successfully?
What I am thinking of is getting the axles off an Airstream wreck.
Old 04-25-2007, 09:04 AM   #4
What is the condition of the axles off the wreck? Was it a roll over? If so, more than likely the axles are out of alignment.
They could be worse than yours.
Late model axles will not fit older coaches.
The weight rating is on a plate that is welded to the axle tube.
CAUTION: DO NOT exceed the rating of your current axles by more than ten percent.
Old 04-25-2007, 09:09 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Henschen axles are suposed have a weight rating tag afixed to the axle. Things to look for are the rating tag, as axles differ because of the number of axles and the size of the original trailer, and down angle of the spindle arm. The Henschen axle will sag over time as the rubber mounts inside the axle age so look at the down angle as a first indicator.
2004 Excursion 4x4
Old 04-25-2007, 09:24 AM   #6
ALL BRANDS OF TORSION AXLES can sag over a period of time, but not necessarily so. That problem is "NOT" exclusive to Henschen.
Sagging has to do with lack of use, and/or bad rubber rods, which is usually dictated by the composition of the rubber.
Old 04-25-2007, 10:44 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If you manage to find a coach that doesn't have bad axles with the correct rating, you need to get both axles from the wreck. The used axles are going to have a different amount of usage, and the spring rate and ride height will be slightly different. Different ride heights will promote higher loads on the "taller" axle, leading to increased tire wear, hotter wheel bearings, and a "wierd" feeling tow.
Old 04-25-2007, 11:38 AM   #8
Absolutely correct.
Old 04-25-2007, 11:49 AM   #9
It really raises the ride height of the coach -- and the legendary stability goes out the window. Airstreams did use leaf springs until ... some time in the '50s? I agree -- you won't find great solutions in this direction.
Old 04-25-2007, 01:11 PM   #10
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Leaf spring axles were stopped in the early 60's for Airstream. (Other manufacturers I have no clue)
You may also have a have a width issue. IE your 70's trailers will be about 7.5' wide, newer trailers could be wider. Up to 8.5' wide. So the axles will be made wider to accomodate.
>>>>>>>>>>Action
Old 04-25-2007, 02:05 PM   #11
Images: 59
I disagree that leaf springs less stable and less desirable. And they do not increase the ride height.
The original single drop axle leaf spring set up used in my '59 is very stable. The axle has more "travel" than a torsion axle, and the very long leaves give a soft ride like an old Continental. Also, you can adjust the ride and load capacity by adding or subtracting leaves. And they don't wear out like a torsion axle.
The above statement aside, I don't know if the same holds true for dual axle set-up, and I certainly wouldn't use a set of used leaf springs, or a set of utility trailer springs.
Old 04-25-2007, 02:54 PM   #12
1975 27' Overlander
High River , Alberta
Originally Posted by markdoane
IThe original single drop axle leaf spring set up used in my '59 is very stable. The axle has more "travel" than a torsion axle, and the very long leaves give a soft ride like an old Continental.
An interesting comment; it's occurred to me that my Overlander rides like an old Cadillac. Go over a bump, and it rises and settles calmly and gracefully.
AlbertF is offline   Reply With Quote
Old 04-25-2007, 03:06 PM   #13
I Also, you can adjust the ride and load capacity by adding or subtracting leaves. And they don't wear out like a torsion axle.
Torsion axles do not wear out.
The rubber rods used by Henschen prior to 1974, did indeed take a set, because of the composition of the rubber.
The rubber rods since 1974 and up, can take a set (be destroyed), by parking the trailer and not using for about 3 years or more.
All torsion axles, regardless of manufacture, can have the rubber rods ruined, by simply not using the trailer, for an extended period of time.
Spindles break, bearings seize, alignment changes, damage from an accident, all can ruin a torsion axle and render it useless.
But wear out, just doesn't happen.
Leaf spring bushings, do wear out.
Old 04-25-2007, 03:43 PM   #14
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Andy,
I think you are just talking about definations. If a torsion axle takes a permanent set, it's worn out. IE not really usable any more.
And spindles could break, bearings could seize, alignment changes or damage from an accident can happen on any axle.
>>>>>>>>>>>>>Action
Sovereign weight and Preferred tow vehicle JLD 1974 - 1979 Sovereign 24 06-26-2017 10:17 PM
Weight 1987 34' Excella 83Excella 1987 - 1989 Excella 6 03-26-2003 06:43 PM
weight specs for 68 Overlander 26D PeterH-Airstreamer 1969 Overlander 5 02-08-2003 03:49 PM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 05:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 09:35 AM
