Old 07-16-2011, 07:10 AM   #1
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
Axle weight?
Anyone have a ballpark on what the Axles would weigh? (10 inch brakes) Thank You
Rollerboy is offline   Reply With Quote
Old 07-16-2011, 08:16 AM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
I'll say in the neighborhood of 150#
tphan is offline   Reply With Quote
Old 07-16-2011, 08:38 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
That is drum to drum, no wheels, tires.
2004 Excursion 4x4
Old 07-16-2011, 08:56 AM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
While not too terribly heavy, the center of gravity is actually several inches to one side of the axle tube. since the torsion arms offset the hubs & drums quite a bit. This makes them awkward to handle w/ one person; if you lift them by the tube they will rotate so the drums are down. I found affixing a steel bar to the axle tube w/ a _heavy_ clamp made moving the axles around easier.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-16-2011, 09:27 AM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Yeah, about 150 lbs each including brakes.
Colin
Colin H is offline   Reply With Quote
Old 07-16-2011, 09:54 AM   #6
HowieE's Avatar
Images: 12
If you are installing along. I made a platform from a 2x6 that reached under both drums or trailing arms at the center of the spindle. I screwed a piece of plywood, in the center of that 2x6, that would reach under the axle tube. This "Tee" went on my floor jack and allowed me to jack the axle into place. This will get you access to the reward bolts first. You pin them and then can jack the axle up to pin the forward bolts.
If you are working along you may want to set the axle on the Tee and then raise each end onto boxes to allow you to slide the floor jack under the system.
2004 Excursion 4x4
Old 07-16-2011, 10:14 AM   #7
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
nope,I have a friend with a mini truck will pick up but was worried about the weight in the bed of truck....thanks all !!
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 07:46 PM
