Old 05-10-2011, 07:44 AM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Axle upgrades
Are there new axles offered for a 71 sovereign that have a higher load capacity than the originals? I am planning on building a new frame and will have some added weight in the airstream.
Darkspeed is offline   Reply With Quote
Old 05-10-2011, 07:56 AM   #2
x
XXXX , XXXX
Darkspeed on my 73 excella the originals were 3500 lbs axles and I upgraded to 4500 lb axles. I bought mine from Inland RV and they were the original design Henschion axles. They bolted right in with no modifications needed. Axis which has bought Henschion does not make the exact same design and some changes to the frame will be needed to the bolt holes and the shock mounts. There are two suppliers for Axis axles, Inland RV and Colin Hyde Restorations. Inland can place your order from the serial number of the trailer and Colin requires measurements to be taken by yourself. Colin's price is lower and from what I understand the brake size is smaller than Inland's.
wasagachris is offline   Reply With Quote
Old 05-10-2011, 07:58 AM   #3
Darkspeed's Avatar
1972 31' Sovereign
Thanks, that's exactly what I needed.
Do you like the 4500's?
Old 05-10-2011, 08:05 AM   #4
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I got my Axis axles from Colin Hyde. You can chose from either 10" or 12" brakes from Colin. I chose 10" brakes because they provide sufficient braking power for the weight of my trailer and they are less expensive.
Lance
Top is offline   Reply With Quote
Old 05-10-2011, 08:08 AM   #5
Darkspeed's Avatar
1972 31' Sovereign
Is there a 5200lb axle for my 31'?
Old 05-10-2011, 08:50 AM   #6
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Personal opinion only BUT goin to a 5200 lbs axle even if available .Will be to stiff. 45 should do what you need unless you are gonna haul a tank inside the traylor
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 05-10-2011, 09:58 AM   #7
Darkspeed's Avatar
1972 31' Sovereign
Well not a tank but I was thinking of building a recessed battery box on each side of the axles when I built the new frame.
Old 05-10-2011, 10:59 AM   #8
flynmike's Avatar
2005 30' Classic
Sacramento , California
Assess your need then order axels
I upgraded my axels on my 05' 30'. I was at the limit for weight and was planning on adding solar panels and more batteries. I was about to order 5000# axels and Andy at Inland RV talked me down to 4500#. Reasons were ride for both the trailer and tow vehicle as well as beating up the trailer with too stiff suspension.
I also went with the hydraulic disc brakes too and along with a Maxbrake controller....just AWESOME!
I think you should weight your trailer, firgure what your going to add and plan your suspension accordingly.
Mike
'05 30' Classic rear queen with an '11 Dodge Cummins Turbo Diesel tow vehicle
Avatar is inflight refueling of an F-15 over Nevada...best job ever!
flynmike is offline   Reply With Quote
Old 05-10-2011, 11:32 AM   #9
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
So, is there a rule of thumb for how far over GVWR + full tanks + other stuff?
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 05-10-2011, 03:18 PM   #10
flynmike's Avatar
2005 30' Classic
Inland Andy said 10% max...too much and you go way beyond what the frame is engineered for....which is what my increase was...maybe a little shy...I went from (if I remember correctly) 4200# to 4500# axels.
Old 05-10-2011, 08:23 PM   #11
Globie64's Avatar
Images: 18
interesting. I was talking to a shop that wanted to up to 5200 on my single axle. I'm taking it to another one who I think it far more competent, the go to guys in the East Bay. All this information to digest, what next?
Old 05-10-2011, 10:10 PM   #12
flynmike's Avatar
2005 30' Classic
How much does your GT weigh? My 65 17' Caravel was 3000# loaded...5200 sounds a little stiff for two feet more of the same vintage...yes....digest/research. And if you have the extra bucks get the hydraulic disc brakes...i just LOVE having them on my 30' Classic.
Old 05-11-2011, 09:42 PM   #13
Globie64's Avatar
Images: 18
I love the idea of the discs, but I think for our little (2850# dry wt, est. 3500 loaded) trailer, the drums are fine. We live in a VERY hilly area and they've been fine so far. I think you're right, 5200 is way too much- with the place I'm taking it to I have some more options. I can hardly wait to have someone ELSE do some work to it.
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
