Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 12-04-2006, 08:10 PM   #1
63Airstream's Avatar
1963 22' Flying Cloud
1962 22' Flying Cloud
1968 22' Safari
Bradenton , Florida
Images: 27
Question axle type? '68 20' Safari
We're soon on our way to go and pick up our newest Airstream, a '68 Safari. We want to bring a spare axle, but are not sure of "type/length", "leaf spring" or "torsion"?????
63Airstream is offline   Reply With Quote
Old 12-04-2006, 08:20 PM   #2
A 1968 22 foot Airstream trailer was built with a "torsion axle."
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-04-2006, 09:12 PM   #3
soldiermedic's Avatar
Florissant , USA
Wow
Hey! Finally another 1968 Safari. I have LOTS of spare parts since I am remodeling the floorplan. If you need something let me know and it will be cheap.
soldiermedic is offline   Reply With Quote
Old 12-04-2006, 10:37 PM   #4
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
interior parts
Steve, I sent you a PM regarding some interior parts I am in need of for the "Landshark" Thanks, Ed
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
BIGED52 is offline   Reply With Quote
Old 12-05-2006, 05:00 AM   #5
. , At Large
The axle will have four bolts and nuts holding it on the frame, and two shock absorbers, and four wires, two per wheel, for the electric brakes. Take along something to lift and support the trailer, and a helper to hold the axle up while you install the bolts. Good luck.
Old 12-05-2006, 06:36 AM   #6
Southwestern , Ohio
Smile
'54,
Neat Wanderer! I have yet to see one of those in person.
I don't know anything about the condition of your '68 or how far you have to tow it home, but I doubt it needs a new axle. The old DuraTorques tend to fail gracefully, the rubber just takes a set and doesn't give you as much "spring travel" as it should. Put new tires on it, repack the wheel bearings, and you're probably good to go. If the old DuraTorque is pretty flat, minimize the load in the trailer and take it easy.
The rule of thumb is that the trailing arms should angle down a little from the torsion tube with the trailer at towing weight. Level is marginal and an up-angle means the axle is ready for replacement.
For what it's worth, the DuraTorque in our 1960 Pacer was fine when we got it. The torsion bar was a little tired, but the brakes looked almost good as new and the wheel bearings were full of grease. We replaced the axle on general principles after a year of camping. Raised the ride height several inches when we did--had to change the hitch height!
Good luck with your new trailer!
See you down the road,
Nuvite
Nuvite-F is offline   Reply With Quote
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
re-plumbed '67 Safari tod47d Plumbing - Systems & Fixtures 4 01-30-2006 11:04 AM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 06:50 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
