Old 04-05-2003, 07:12 PM   #1
axle travel
Nice to meet everyone! I have a 1965 19' Globetrotter, the question I have is how much axle travel should I have on the tortion axle? when I jack up the one side the tire only drops about 2".
The reason I am asking is that when towing the beauty rides like a old lumber wagon, I just switched the tires from 7.00-15 to a radial 225/75/15 haven't had it out yet to see if made any change. before you ask I, Yes I have had the tires balanced but have not pulled the shocks yet. Can they restrict the axle movement? Thank You for all inputs, Doug
Doug Diepenbrock is offline   Reply With Quote
Old 04-05-2003, 09:56 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
D,
The shocks should not restrict axle movement.
2" drop is most likely correct. It is a torsion bar axle. No metal springs. The material inside the axle that is being twisted is a rubber like compound.
The radial tires do not have the same charistics of bias ply tires. The side wall of a radial is more flexible. So you may experience more trailer sway with those tires. And the 225's may squat more and as a result may contact the insise of a vintage wheel well of some trailers. Hope the tire is an ST, as in the first 2 letters of the tire size. And the tire max load rating should be high enough for the entire load. Max towed load as weighed at the scales. Divided by the # of tires on the trailer. This # should be less than what is stamped on the outside of the tires as to max load. How much less? Well this is your safety margin. I suggest 10%.
>>>>>>>>Action
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Axle Question drex Axles 7 07-30-2007 05:50 PM
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
Sorry. Another axle question whistler Axles 6 08-28-2004 10:33 AM
New Axle Installed. Success! DanLyle Axles 0 04-24-2003 11:00 PM
