Old 03-26-2008, 08:42 PM   #1
azfiredog300's Avatar
Surprise , Arizona
Axle torque
O.K. so I started installing my axles today and was able to get the first one in with only a little trouble, took about 1 hour by myself(wheels and tires were already off). Question now is that the axles didn't come with instructions so I am a little unsure of what torque to tighten the bolts down to. Any one know this, and also what torque for lugnuts?
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 03-26-2008, 08:56 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Jerry,
Not sure on the axle bolts but the lug nuts are 110#.
Old 03-26-2008, 10:10 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
The bolts that secure the axle to the frame's mounting plate are hardened. Tighten them as tight as you can get them with regular hand tools.
I'd say to about 80-100lbs, as a loose guideline. Don't be shy, they're good size bolts....
Uwe
www.area63productions.com
Old 03-26-2008, 10:25 PM   #4
The Henschen axle installation for 1969 and up years, is the reverse of removal.
We supply 5/8 inch grade 8 hardware.
You can torque the bolts to 100 to 120 foot pounds.
Lug nuts can be tightened to 100 to 110 foot pounds.
Torque wrench..necessary? Kistler Wheels, Hubs & Bearings 20 08-01-2016 06:15 PM
What is the correct torque? IrishRover2 Wheels, Hubs & Bearings 4 11-19-2006 06:20 PM
axle nut torque value?? jgouras Axles 2 07-03-2005 04:41 PM
Do I need More Torque or More Horsepower? mdeneen Tow Vehicles 52 11-02-2004 06:06 PM
torque converted dbyar Mechanics Corner - Engines, Transmission & More... 8 03-05-2003 05:21 PM
