Old 11-15-2009, 10:47 AM   #1
1965 17' Caravel
langley , British Columbia
axle swaps
I recently bought a 1965 caravel ,,,it needs a new floor and i`m putting in a new interior. The brakes and axles and wheels need to be replaced,,,i have found a 2006 airstream frame ,,(i haven`t seen it yet,but it`s only about 20 miles from where i live),it is complete with holding tanks,,,it was a tandem axle trailer,i think it is 22 ft.,, Could i use the axles,brakes and wheels as replacements for my trailer? I`m thinking the axles should be 3000 lbs. Each,,,one more thing,,,,the wasroom in the back of the trailer,,,the tiolet on the right seems to sit quite high,,it`s on a one piece moulded fiberglass floor ,,which includes the shower and the sink,,,do most people stay with this design,,,or change the position of the toilet,,,the window seems to be in the wrong place for the tiolet,,,,,thanks keith langley ,,, british columbia
trout-fly is offline   Reply With Quote
Old 11-15-2009, 10:49 AM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Don't know on the bathroom stuff, but call inland rv (www.inlandrv.com) and ask Andy on the axle stuff. He could tell you original specs for the 65 and for the 2006 and then you could make a more informed decision.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-15-2009, 11:43 AM   #3
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
The new trailer is too wide... even if it's a 22ft'r.. it'd be an 8ft wide trailer. Your trailer is 7'6"... the wheels wouldn't tuck into the bodywork.
Marc
Old 11-15-2009, 06:16 PM   #4
1965 17' Caravel
thanks,,scott,megan and mark,,,,i was thinking of using the 2006 torsion bars with the brakes,,and then putting in a new axel,,i could make the axle the right width and weld the torsion bars to the new axles,,,haven`t got under the trailer to see how the old axle is attatched,,,but the axle looks to be a 2 by 2 square tube which doesn`t seem very big,,,i`ve built a few car trailers,,one was a walking beam ,,,the other 2 were with springs and a axle,,,i will phone inland rv and see what they think,,,,,thanks keith
Old 11-16-2009, 08:37 AM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Keith, This file will give you a little info on how the axles work. http://service.airstream.com/files/l...22708290a0.pdf. How about some pics of remodel of the Caravel.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-16-2009, 09:44 AM   #6
Lee.
I have no idea where you found that article, but it should be deleted.
First of all, I wrote most of it.
Secondly, there are a number of errors in it, that have long been corrected.
Third, the last paragraph, "Checking your axle" I did not write, and is incorrect. I have no idea where that paragraph came from, or who may have added it to the article.
A bad axle can, upon removing the weight, have the torsion arms return below horizontal. However, that has nothing to do with it's ability to carry a pay load.
Therefore, that paragraph states a test that is improper.
The updated article can be located either in our web site, Inland RV Center - The Nations Leading Expert in Airstream Innovations, or in the Airstream Central web site.
Please, for sake of accuracy, do not post that article for someones reference, as it is misleading.
In fact, see if you can get a moderator to change the link you posted, to one that is correct.
Thanks.
Old 11-16-2009, 09:57 AM   #7
1967 22' Safari
1960 Caravel
Images: 8
Originally Posted by Inland RV Center, In View Post
Lee.
Thanks.
Andy if found the article here. Airstream, Inc :: Service Home. This article was posted by Airstream, Inc :: Home.
So you are saying that Airstream(the mothership) has posted wrong information?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 11-16-2009, 10:04 AM   #8
So your saying that Airstream(the mothership) has posted wrong information?
Lee.
Yes, Airstream then added that last paragraph, that is wrong, according to Henschen.
Also, several changes to that article were made some time ago.
I will call Airstream and see if they can (will) update the article information.
Thanks.
Old 11-16-2009, 12:05 PM   #9
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
You might want to look into Dexter axles. That's what I had put on my Caravel 4 years ago, and it was fairly inexpensive - even complete with new brakes. A local RV shop measured the Caravel and custom ordered the size I needed. Most of the expense was in installation, but it sounds like you can do that yourself.
The 2006 axle is going to be too wide for your caravel, and I don't think you can shorten it.
Stephanie
Old 11-16-2009, 01:51 PM   #10
1965 17' Caravel
thanks for all the input,,,,it`s made me slow down a bit,and to think this out..the 2006 trailer was written off in late 08,,,the wheels,rims,brakes,all the holding tanks and every thing that was under the body is still their and is supposed to be in nearly new condition,,,i helped a guy wire his garage,,he used to own it,he phoned the guy he sold it to,asked if it was for sale, and it was, for the same price he got it for $600.00...my problem is,,are the brakes,drums,rims, wheels,mybe a holding tank worth the cost,,,thanks keith the local airstream dealer in canada is very,very,very expensive
Old 11-16-2009, 02:07 PM   #11
Airstream axle info
Lee
I have talked with Airstream, and they will revise that axle information., that's in their web site.
They, at this point, do not know who added the last paragraph, but that will be corrected as well.
Old 11-16-2009, 02:25 PM   #12
1967 22' Safari
1960 Caravel
Images: 8
Lee
Thanks for the update Andy, I will look forward to Airstreams revision of there library files on THE DURA-FLEX Rubber Torsion Axle GKN (Henschen ).
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 12-05-2009, 10:26 AM   #13
1965 17' Caravel
I`ve taken the old axel out of the caravel,,,it was quite easy,,,it was held in by 4 7/8 nuts and bolts,,,there was also a weld along the bottom of the frame to the axel(not a good thing),,,,there is a plate about 12ins. Long that is welded to the frame and it hangs down about 2ins.,,,it has a cutout for the axel,,,so when the axel is in,,,,,,, the top of the axel sits against the bottom of the frame,,,,it also has a shock braket on it,,,,my question is,,,,do you need a shock with a torsion axel,,,doesn`t the rubber in the axel act as the shock,,,,also welding anwhere on the axel could cause damage to the rubber ,,,,i want to order a dexter next week,,,,the specs. On the trailer call for a 22.5 degree drop,,,,can i put in a 10 degree,,,i would like the trailer sitting lower ,,,,thanks keith
Old 12-05-2009, 10:34 AM   #14
Why did Airstream, install the shocks?? And still do. Especially on a single axle trailer, a shock is very important.
But, it's your trailer, to do with as you wish.
The 10 degree starting angle will not be that way, once you put a load on the axle. That would perhaps cause a problem depending on the size tires you would use, that could hit the wheel well.
The original axle mounting bolts were 5/8 inch.
Straight Axle vs Drop Axle Sound off. soldiermedic Axles 12 03-24-2009 06:39 AM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Old axle vs New axle feedback . . . GetOutDoors Axles 21 08-09-2007 01:59 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
