Axle swap - propane line location?
I am halfway through my axle swap and have come up with a bit of a problem. The propane line for the water heater went under the front axle and over the rear one. ( I think that line had been replaced - it was copper with some sort of plastic cover, all the other lines are just copper.) I removed the gas line in order to get the old axles out. On my previous trailer, 75 Trade Wind, this was not a problem - but I can't really remember exactly where the water heater was located. (I think it was about the same - road side behind the axles.
Doe anyone have an idea of where the propane line should go? There is not a great deal of space between the frame rails and the "boxes" that cover the fresh water and holding tanks. I think that I can snake a new line through but it will be a tight fit and I am not sure how to fasten the line to the frame.
Any insight will be appreciated.
Whit Nash
