Old 04-10-2014, 07:13 AM   #1
1990 29' Excella
Long Island , New York
Axle Still Won't Drop
Got all the bolts out, it appears AS notched out the tank shroud to fit over the axle flange. After sleeping on it I think I'm gonna try and cut the shroud. Idk any better ideas? for detailed description see previous thread post#13
Jeepjunk4 is offline   Reply With Quote
Old 04-10-2014, 08:31 AM   #2
1976 31' Sovereign
Oswego , Illinois
Smile axle won't drop
Have you tried to wedge screw driver or some thing between bottom of frame & flange as flange is widest at point of top of angle cut, I had to do this when I changed mine then had to jack in place as pretty tight fit [no slop].
Old 04-10-2014, 09:33 AM   #3
1990 29' Excella
I did try to pry it with a big #%$ prybar and no go. Made a few test bores with a drill bit to see what kind of clearance I had and I think I'm tasting victory!!!
ID:	209327   Click image for larger version
Old 04-10-2014, 10:17 AM   #4
Mexray's Avatar
1978 28' Ambassador
Morada , California
Wow...Mine just dropped out of our 1978 rig when I changed em'...
Of course the tank shroud was added after the axles, and there could be some 'interference' there, but gravity should make the axles drop on their own...
If the axles are still 'tight', and all the bolts are gone, sounds like they are 'wedged' up in there - are they collapsed to such a stat that there's some interference with the axle 'levers'...?
Fun stuff, isn't it...
Ray & Pat; Morada, CA
Old 04-10-2014, 11:41 AM   #5
1990 29' Excella
I know this is crazy, the axles are out now. I read the stories, 4 hours and done, that's the rigs with the flat bottom, easily accessible bolts,easy, done. Mine is one of those and I know the mid 80's excellas are the same way, where the fresh water tank is lower than the front axle, and the rear axle is sandwiched in between the tanks!!! And what ur looking at in the pic, looking from the ground up, is the part of the grey tank cover that I had to cut out to get the axle to drop. The light colored metal is the metal tank cover that I had to notch out, and at the bottom of the pic that dark strip is actually the bottom of the frame rail. That's how tight that tank is to the frame.
Old 04-10-2014, 12:18 PM   #6
1981 31' Excella II
New Market , Alabama
I think mine has bolts on the axle mounting plate as well as on the frame and you know those suckers are not coming out.
Glad you go them out.
Perry
Still new, still starting Bullit Member Introductions 25 04-25-2014 06:36 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
Drop in axle solution? BabyBoomers Axles 9 02-21-2011 09:09 AM
Step that won't drop down Bill McNamara Steps 2 03-28-2009 10:19 PM
Straight Axle vs Drop Axle Sound off. soldiermedic Axles 12 03-24-2009 06:39 AM
