Old 07-13-2008, 11:51 PM   #1
Potters , Idaho
Axle shipping weight
Can anyone tell me the actual shipping weight of 3200# Henschen axles with wheels and shocks?
phoney is offline   Reply With Quote
Old 07-14-2008, 04:58 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Axles are about 250 pounds each, shocks are about 5 pounds each, and wheels depends on aluminum or steel wheels.
Old 07-14-2008, 07:31 AM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Phoney
I bet if U would PM Andy at Inland RV's he can tell ya what they weigh cause he ships enough of them. He is the only dealer for Henshen in the USA.
Roger
Mikethefixit is offline   Reply With Quote
Old 07-14-2008, 11:14 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Call Henschen 937 596-6125
Why are you including the Wheels in your question? Axles are sold Hub to Hub and do not include the wheels or the shocks.
2004 Excursion 4x4
Old 07-14-2008, 02:39 PM   #5
Potters , Idaho
Good point I meant hubs.
Old 07-14-2008, 02:57 PM   #6
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Remember the shipping weight must include pallet and banding and about a zillion feet of duct tape holding the bags of lug bolts to the assembly...
Old 07-14-2008, 03:09 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I think a mistake was made, but
Terry, in my opinion, gave you the best answer @250 lbs each loaded axle.
My axles came strapped together just as pictured below - No pallet.
But I just now pulled out the freight slip for my Overlander's TWO axles from Andy, and the "TTL WEIGHT LBS." was listed at 276.
Now I was missing the promised Grade-8 hardware, but 224 lbs for the addition seems a bit high...
For estimating purposes, go with Terry & budget a 500 pound freight charge.
Tom
Old 07-14-2008, 03:30 PM   #8
1966 17' Caravel
Do you think this is an important repair on a 1966 Caravel? Andy has suggested it but he has not seen it, looking for other opinions.
antmagrat is offline   Reply With Quote
Old 07-14-2008, 03:42 PM   #9
TomW's Avatar
1967 26' Overlander
Camp first
antmagrat,
I remember the angst you are experiencing now. I know nothing about your Airstream's condition.
My recommendation, for you, is to get your Caravel camp-ready, and go out and use it for several trips. If you decide you like camping AND you think camping in a '66 Airstream Caravel is the best way to do it, then replace your axle.
You more than likely have the original axle & it is beating up your Airstream.
But if you don't like the whole experience, why waste your money? Vintage Caravels are extremely desirable, and you can sell it for big bucks as is.
Tom
Old 07-14-2008, 03:43 PM   #10
Well Preserved
1993 21' Sovereign
42 year old axles are almost certainly gonners. Don't believe people when they tell you life begins at 40...
Old 07-14-2008, 05:44 PM   #11
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
You'll soon learn that Andy's opinion has a lot of years and experience behind it. You might do better searching somewhere else, for less money, but if your time and energy is valuable one phone call to Andy and you got what you need and the parts you need. Then you can spend your searching time on something else.
NevadaGeo is offline   Reply With Quote
Old 07-15-2008, 01:45 PM   #12
1976 24' Argosy 24
Milford , New Jersey
Two 3500lb dexters came on a pallet. Shipping weight listed as 298lbs. Not as heavy as thought they would be. G
Gkiesel is offline   Reply With Quote
Old 07-15-2008, 02:10 PM   #13
Bare axles are about 145 pounds, each.
Complete axles weigh about 240 pounds, each.
Freight lines will also add the weight of the pallet, as well.
Old 07-15-2008, 03:15 PM   #14
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
This is our 1965 Caravel on October 27th, 2002. We didn't know at the time that old axles were a problem. Had we known, we would have changed it and not had this problem.
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Axle Weight Ratings Gkiesel Axles 7 06-03-2008 02:01 PM
trailer/tow vehicle axle weight regs sumfari Local Regs & Licensing 2 02-15-2008 05:43 PM
Axle weight ratings Lumatic Axles 20 05-15-2007 10:16 AM
Front Axle weight alfalsetto Airstream Motorhome Forums 0 02-24-2004 10:33 PM
