Old 03-14-2010, 07:56 PM   #1
larry b's Avatar
1975 31' Sovereign
howell , Michigan
axle seals / grease??
Getting ready to repack the bearings for the first time, since my purchase in Sept of 09.
Read a few threads regarding axle seals are hard to find. Anyone out there know where I can purchase a set?
Planning on using Mobile 1 grease anyone have issues with Mobile 1 ??
Thanks for the help!
larry b is offline   Reply With Quote
Old 03-14-2010, 08:01 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Take out one of the old seals, and head to your local Napa. The last set I got there cost about $4 each, but that price varies.
I've never had a problem with Mobil 1.
Old 03-14-2010, 08:06 PM   #3
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Larry,
We just ordered second set of seals for our 2005 International. Here's what we ordered:
1 5331099 DEXTER 2.25" ID Grease Seal #010-036-00 8
$4.29 $34.32 2 5331010 12" x 2" Electric Brake Assembly - Right Hand / 5.2k #K23-106-00 2
$43.99 $87.98 3 5331009 12" x 2" Electric Brake Assembly - Left Hand / 5.2k #K23-105-00 2
$43.99 $87.98We bought these from Eastern Marine Trailer Parts Superstore. They answered email questions rapidly and accurately, shipment went out on day after we ordered, and parts arrived less than one week later. We'll see how the stuff works out when we get to my father-in-law's house in a couple of weeks.
Hope this helps,
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 03-14-2010, 09:01 PM   #4
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Don't know about the seals, but I do use Mobil 1 all of the time and it has worked great / held up well. Whenever I repack every couple of years, it sure isn't because of the grease, but only because I like to check the brakes out.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 03-14-2010, 10:19 PM   #5
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
There are seals with and without stainless coil springs inside the seal mating surface. Price will vary. I prefer the seals with springs as I don't remove my bearings every year.
My local repair guy who specializes in transmissions, drive lines, and rearends says "high temp grease" should be labeled as such.
I would check those bearing surfaces closely. I don't know if Airstream is using chinese bearings but, if they are, look for pitted surfaces.
Around me in Tennessee, there is an outfit call "Motion Industries" that is a to z on bearings and seals. They are owned by the same holding company that ownes NAPA parts stores.
There are gray market bearings being slipped into the USA, I don't know about seals but, wouldn't hurt to be careful and verify the sellers source.
wingfoot321 is offline   Reply With Quote
Old 03-14-2010, 10:38 PM   #6
grease seal.
The correct seal is double lipped and has a stainless steel spring in it, and is top of the line.
Cheap grease seals, are exactly that.
Old 08-24-2010, 07:05 PM   #7
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
spindle seals
I checked the seals in the axles that I got from Inland RV and they are the imported type with no springs. Car Quest said that they have had no problems with the imported seals. Imported seals $6.00 plus and U.S. seals with spring is $18.00 plus. Wow!!!!
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 08-24-2010, 07:35 PM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I've run both types of seals in my tandem bass boat trailer. I repack every year and have not had a problem with water with either type. A boat trailer bearings live in a much harsher environment than an Airstream so I would think that as long as you repack every year or so and don't run in deep water the cheaper one should be fine. The load on an Airstreams bearing will in many cases be much higher than even a big bass boat so cheap bearings or cheap grease could be a big mistake.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-24-2010, 07:37 PM   #9
Beth.
US double lipped seals with springs are no where near $18.00, not even from Airstream.
grease seals delmer Axles 2 08-05-2009 08:59 PM
Grease seals Inland RV Center, In Axles 0 07-24-2009 02:40 PM
Grease Seals niftypkg Axles 6 03-11-2007 03:02 PM
grease seals for wheel spindles BigAl Axles 8 04-17-2005 01:34 AM
Grease seals, hub trouble Silver Annie Axles 10 11-03-2002 11:46 AM
