Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 07-22-2010, 03:02 PM   #1
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Axle Replacement went well.
Just finished replacing the axle on my 65 Safari and just wanted to say thanks to Andy and his staff at Inland RV. The new axle fit like a glove. I had to drill new holes but that was not too bad. The hardest part was taking the old bolts out. I would recommend the use of a torch to cut the old bolts which will save much effort and time. I did the entire job myself and it took about 6 hrs. The trailer now sits almost 2 inches higher. When I got the old axle out (it still had some down angle) it was froze. The rubber dampers inside the axle had turned hard. My wife pulled the trailer around the block while I was in it before and after. Before bumps were sharp and I felt every crack in the road. After the new axle was installed the ride was really smooth. Thanks Andy and Inland RV.....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 07-22-2010, 03:19 PM   #2
Thank you.
Yes indeed, Airstream's love a soft ride. Most people do too.
Andy & Staff
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-22-2010, 04:17 PM   #3
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Funny,
The hard part was drilling the new bolt holes, removing the old bolts was easy.
It raised my unit 2 inches higher too
Tows great
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Looking for a replacement hub to fit my tag axle Mr. D Classic Motorhomes 8 04-10-2010 03:36 AM
Another Axle Replacement The Flintstones Axles 6 09-06-2007 12:38 AM
Axle replacement Pick Axles 92 02-18-2006 08:27 PM
Axle Replacement ??? FC54 Axles 6 10-10-2003 05:01 PM
