Old 01-10-2009, 08:08 PM   #29
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I think someone (HiHoRV??) posted a pic of his axle that he cut in half and it looked like that drawing..... Andy said that was an "experiment" that Henschen used for a while... but then went back to the conventional rod after having better results with the tried and true rod...
Marc
Old 01-10-2009, 08:09 PM   #30
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
To Inland Andy
First - I always appreciate your posts, and continue to hope that you'll consider opening another office on the east coast - Virginia Beach could be a Great Location!
This is a "get well soon" too. Knee replacement surgery and the physical therapy afterwards is NO fun, but within 6 to 10 weeks you'll feel like you got new axles, shocks, AND your running gear balanced!
We'll all have to start calling you "Smooth Andy". Take care, and don't over-hitch yourself while recovering.
Paula Ford
Virginia Beach
Old 11-25-2013, 10:40 AM   #31
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
this is a great axle thread worth bumping up for attention..
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-08-2014, 10:13 PM   #32
Toronto , Ontario
Hi, did the axle refurbishment really only cost you $100? was it per axle? How hard were they to remove and reinstall? Also, how long did the refurbishment process take? I am from Canada but I am only 6 hours away from Axis products...I think it's worth the drive. Buying new axles and disc brakes will break the bank.
engman is offline   Reply With Quote
Old 02-09-2014, 07:15 AM   #33
aquinob's Avatar
Portsmouth , Virginia
As far as I know, nobody rebuilds the axles any more. This post was from 2008 originally. Times have changed.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 02-09-2014, 07:24 AM   #34
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I understand the folks referred to in this thread still do this but only in Indiana. I would contact them.
AIR #005
retired!
Old 02-09-2014, 07:50 AM   #35
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Axis Products purchased Henschen about 3 years ago, then merged with Al-Ko to form Al-Ko Axis about 2 years ago. They do not rebuild torsion axles anymore. I have installed their axles on Airstream's & other vintage trailers for the past 8 years or so. They made me their National Distributor about 2 years ago.
Colin
Colin H is offline   Reply With Quote
Old 02-09-2014, 08:00 AM   #36
Rebuilding torsion axles was deemed a "no-no" by Henschen, many years ago.
The reason was and is, the inside of the square tube, can and does collect water. Since the tube is steel, the water causes rust, which weakens the tube.
How much weaker does the tube become depends on how much rust has formed.
The liability rebuilding a torsion axle, for the rebuilder, far exceeds the rebuilding costs and/or profits.
Old 02-09-2014, 01:05 PM   #37
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Remember this was back in 2008.
Yes I did have my axles rebuild for less than $100.00 I think the actual price was $66.00 for both, dropped the axles off in the morning and picked them up in the evening.
When I pick them up I was told they would have sold me a 2 new axles with 10" brakes for $600.00 for the pair. They also said they have the prints for all Airstream trailers and can build direct bolt on replacements including shock mounts for any year trailer.
After the total rebuild of axles, brakes and bearings I spent close to $600.00, see post #21 of this thread for a breakdown of what I spent.
In 2010 I bought a 1966 Globetrotter, I called Axis and order a new axle I think it was a little over $300.00, it was a perfect fit.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 02-09-2014, 05:50 PM   #38
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
The vendors know the story...so let it be written so let it be known
AIR #005
retired!
Old 02-13-2018, 12:40 PM   #39
1971 31' Sovereign
Goshen , Indiana
Originally Posted by bmklawt View Post
The first of many projects
I noticed my axles were in the horizontal position so I thought I'd take a look and see how bad the are.
When I jacked the trailer up the the tires didn't stay on the ground they moved right up with the trailer, after removing the wheels I found the spindle arms to be locked up solid with zero movement. I also found the shocks were shot they are regular automotive shocks and not the kind the can be mounted horizontally.
Off they came and in the next few weeks I will be traveling to Indiana to pick up new ones at the same time I will go to Palomino Parts in Colon Michigan, for a new water heater and furnace and to Goshen Stamping in Goshen Indiana and pick up some lift parts for my popup.
Here's a few pics of the axle:
I know it's been a long time since this was posted, but I was wondering what shops you worked with. I am from that area and would like to work with someone local when I finally buy an airstream. Thanks!
emilyweav is offline   Reply With Quote
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Another Axle Replacement The Flintstones Axles 6 09-06-2007 12:38 AM
axle replacement part I Rhonda Axles 18 07-10-2007 10:33 PM
Axle replacement Pick Axles 92 02-18-2006 08:27 PM
Axle Replacement ??? FC54 Axles 6 10-10-2003 05:01 PM
