Old 09-28-2016, 05:30 PM   #1
1974 Argosy 26
Dana Point , California
Axle replacement Question
My new axles are going to be shipped from Colin this week. I am preparing to do the install shortly after I get them.
The propane line to the water heater runs just beneath both axles. What is the best way to get the old axles out and the new axles in with the propane line situated there?
Peter Culp is offline   Reply With Quote
Old 09-28-2016, 05:37 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
1: Remove the LP line
2: Replace the axles
3: Reinstall the LP line.
I'm not sure if that's what you wanted to know, but that's what you asked.
Old 09-28-2016, 05:38 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Cut the line. Just make sure you get a flared connector, approved for gas, to put it back together. Don't cut directly under the axle but off to one side. This will leave the longer piece of piping as the only side you will have to bend.
If there is enough room above the axle tube you may want to install the pipe above the axle to correct the mistake they made at the factory.
2004 Excursion 4x4
Old 09-28-2016, 06:02 PM   #4
Well Preserved
1993 21' Sovereign
He shouldn't have to cut it. There's a connector visible in the photo that probably goes to the water heater. Simply unbolt it there, and follow it forward to the next connection, and unbolt it there. Drill out the rivets holding the retainers to the belly pan, and the LP line will come off.
Old 09-28-2016, 06:13 PM   #5
1974 Argosy 26
I saw the flare joints that I can remove. I did not see those before. Thanks.
Old 09-28-2016, 06:13 PM   #6
1974 Argosy 26
you guys are the best
Old 09-28-2016, 08:36 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Removing the line at the fitting is the best assuming the fitting do not cause issues.
If something else needs to be done, my recommendation would be to replace the lines assuming you are speaking about the 1974 trailer in your avatar. 42 year old lines may not be as flexible as they once were. And they have been exposed to 42 years of dirt and corrosion which may be an issue as well.
A new line would be flexible and one could rely on a tight connection with new fittings.
>>>>>>>>>>>Action
Old 09-28-2016, 10:52 PM   #8
1991 25' Excella
Stanfield , Oregon
On I cut mine the line then spliced in a tee and ran a new line to the rear. It allowed me to put a lp quick disconnect for my gas fire pit.
SpletKay06 is offline   Reply With Quote
Axle replacement / Floor Replacement - Newbies! toesonoz Vintage Kin 12 07-02-2016 06:05 PM
Question about axle replacement PJ Beans Axles 1 01-23-2015 07:37 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 02:25 PM
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 05:40 AM
Axle replacement question-are they really worn out? oldvws Axles 1 12-30-2002 09:04 AM
