Old 07-12-2007, 10:33 AM   #29
Miss Rivette
airedale's Avatar
1965 17' Caravel
Hell , Michigan
Send a message via AIM to airedale Send a message via MSN to airedale Send a message via Yahoo to airedale
Axel ..........$1600.00
Shocks........ $108.00
Drum Balance Job......$40.00
Lunch and Beer......$50.00
Getting Drunk while changing the axel and having great time.........PRICELESS!!
Laura Miss Rivette 2008
W8JUZ --......--
"Support Search and Rescue, GET LOST!!!!"
Operation "SAVE RUDY" Strike Team (Charter Member)
Check Out My New Airstream Blog
airedale is offline   Reply With Quote
Old 07-26-2007, 02:09 AM   #30
calitrotter
1963gt's Avatar
Berkeley , California
my axle was welded onto the frame
I recently had my axles replaced by a local reputable shop.
they ordered a custom axle from dexter per their measurements.
i supplied the "napa" shocks.
when i got my trailer back i noticed that the axle was not bolted on, as i would have expected, but welded to the frame.
I have towed it over a thousand miles since, with no problems. the brakes work well.
I am not sure how i feel about the welding versus bolting.
it seems like i should have been consulted and perhaps the future value may be reduced by this..
i would like to approach the shop with my concern, but what would i get out of it?? the "damage" is done.. unless it is not a big deal..
i don't know, that's why i am putting it out here.
I probably should have gotten the henshen product..
any thoughts?
mike
1963 Globetrotter OHIO
1988 Ford E150 Sportsmobile
2001 Buell X1 Lightning
2002 Isuzu Axiom 4x2
1963gt is offline   Reply With Quote
Old 07-26-2007, 07:46 PM   #31
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
1963gt
I suppose that it is OK to weld it to the frame it is certainly easier to do it that way in a shop setting. While it will take some doing to get it off if ever needed it can be done without damaging the trailor. I assume you went with Dexter because of the price? I do feel that the shop should have given you the option to bolt or weld, since they had to unbolt or cut the old bolts off and drop the old axle out. I would think that if the axle is correct for your trailor it should last 20 or so years, so I do not think you have to worry about anything for quite some time. It is fairly common for other trailors to have the axle welded to the frame, and perhaps they just were noy familiar with Airstreams. I hope it does well for you and gives you and your family years of adventure.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 07-30-2007, 10:16 AM   #32
calitrotter
1963gt's Avatar
i called the shop
i talked to the guy who installed my axle, and he assured me that the installation was solid and he has welded axles many times.
i have towed it approximately 1500 mile with no incident.
i suggested that he bolt it on. since the holes don't match new holes would have to be drilled and the 1/2 in #8 bolts installed. he did mention an extra charge for that.
but i may insist the he complete the job to my satisfaction, since i should have been consulted regarding the welding..
i'm not sure why i chose the dexters.. cost was definitely a factor.
mike
Old 07-31-2007, 08:35 AM   #33
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Send a message via AIM to Airboss Send a message via MSN to Airboss Send a message via Yahoo to Airboss
Dave (DragNwagon) and I put a new axel on my 65 Caravel the weekend after we did his and we had to drill the 1/2 holes on it. It was very easy to do. In fact we started about 9:30 AM and the Caravel was back ready to tow at 1:15 PM. Not bad for a couple rookies...We feel like pros now.. Ralph
"If your not living life on the edge... Your taking up too much room. WANTED, Single lady who loves and has a Airstream. Please send photo of Airstream and Tow Vehicle
Operation "SAVE RUDY" Strike Team (Charter Member) RALPH, KW8G..WBCCI # 4201 Metro Detroit & 4CU TAC # MI-007
Airboss is offline   Reply With Quote
Old 07-31-2007, 11:18 AM   #34
1970 23' Safari
Ralphie...we are pros now!
Dave
TAC# MI-1
Old 07-31-2007, 06:37 PM   #35
Miss Rivette
airedale's Avatar
1965 17' Caravel
Hell , Michigan
hey, i would agree, you did a great job with the Caravel!
W8JUZ --......--
Old 07-31-2007, 08:48 PM   #36
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Thats right,, I forgot,,We are PROS AT IT!!!!!
Old 03-12-2009, 05:13 PM   #37
BarryIowa's Avatar
Polk City , Iowa
Informative and HILARIOUS thread. Thanks.
BarryIowa is offline   Reply With Quote
Old 03-12-2009, 06:04 PM   #38
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Glad u liked it.. Hope u read part 1 as well...
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Axle replacement Pick Axles 92 02-18-2006 08:27 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
