Old 08-29-2010, 07:53 AM   #1
fletcher , North Carolina
axle replacement options 1969 Tradewind
Hello from western North Carolina,
I have a 1969 Tradwind "project" trailer (a lot of work to do)
Is the Dexter axle the only replacement option now that the Henschen plant has closed?
What information is needed to get the correct replacement axles?
thank you,
Paul
paul z-air is offline   Reply With Quote
Old 08-29-2010, 08:04 AM   #2
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Axis axles are another option and I think that Henschens are still available though not currently being manufactured.
SilverHoot is offline   Reply With Quote
Old 08-29-2010, 09:09 AM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Paul we ordered 2 axles from Inland Rv (the henschens) a few years back for our 69 tradewind and 100% would do it again if we needed to. It literally took longer to pack the wheel bearings than it did to install both axles. Removed the old bolts, jacked the new ones in, bolted right up in the same holes, new shocks, then did the brake assemblies with new bearings etc included in the kit. Is a little more expensive than the other brands but well worth the price difference for a 100% guaranteed fit with zero modification needed.
I think I remember reading him having a significant supply to get them through the down time of moving the plant.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 08-29-2010, 10:11 AM   #4
thank you,
Paul
Paul.
Hundreds of Henschen axles have been inventoried, to cover the down time.
Old 08-29-2010, 11:09 AM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I used Axis axles that I ordered through Colin Hyde of Colin Hyde Trailer Restorations (Colin Hyde Trailer Restorations). Colin has worked with Axis and he knows how to spec the axles for your trailer. Might give him a call, I was very happy with the service, axles are first rate and I saved a lot of money.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is online now   Reply With Quote
A/C Replacement options (67 Overlander) mccaa891 Furnaces, Heaters, Fireplaces & Air Conditioning 6 09-18-2007 07:02 PM
Options for furnace replacement soldiermedic Furnaces, Heaters, Fireplaces & Air Conditioning 60 02-24-2007 09:41 PM
What about the bend in my 1969 axle? commander31 Axles 3 01-29-2007 07:28 AM
Univolt Replacement - What are best options? toga Electrical - Systems, Generators, Batteries & Solar 9 09-28-2006 06:28 PM
